Old 08-18-2015, 09:32 PM   #415
kanaga
Drives: '08 yaris sedan
It is possible that your sedan is not included, as sedans are a different body and are built in a different factory, so they may have the seams sealed that are the cause of the issue.
I had received notices from Toyota regarding this issue for my 08 sedan.
kanaga is offline   Reply With Quote
Old 08-30-2015, 12:16 PM   #416
Be_Jammin
Drives: 2010 Yaris Liftback A/T
I checked my bolts a month or so ago. After 5 years / 50KM in southern Ontario, The driver side bolt was like new, the passenger bolt was slightly rusted on surface. Some black liquid came out with the passenger one. I put vaseline (I had no grease) on them and reinstalled.
These were the original bolts based on the head markings.
Question: There are quite a few other bolts on front underside that look quite rusty (At least the heads do), should I be concerned about this?
Be_Jammin is offline   Reply With Quote
Old 04-03-2016, 04:36 PM   #417
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Toyota often seems to change part numbers, and sometimes with no visible change to the part (it could be something as simple as them changing suppliers for the part and hence revving the part number). I bought some of the 90119-14151 bolts and there does not appear to be any difference in strength rating, plating, etc. with the new part number.
I personally plan on checking (and perhaps replacing) the bolts once per year.
i just got to replacing the bolts for the new and improved. there is some difference in the stamping, probably improved strength, but don't know how to decode it (see picture).
i did remove the old ones a couple of years ago to inspect, grease, and retorque. there was some superficial rust, but it didn't get any worse after nice greasing the whole length. in retrospect, i didn't need to replace it.
but, the car never saw any snow or ice. it would be very different in the salted roads states.
jack black is offline   Reply With Quote
Old 09-29-2016, 09:16 AM   #418
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
does anyone know where you could get the oem bolt? my car is way past the extended mileage and I want to replace it just because
BobTheYaris is offline   Reply With Quote
Old 09-29-2016, 11:47 AM   #419
snowsquirrel
Drives: 2008 Yaris 5dr LB
LCA Bolt
I purchased mine thru Parts.com in USA
the original part # is 90119-14126
but 90119-14151 will work too.
the ones I removed from the vehicle looks ugly, but not as bad as others posted here, considering I'm in Canada where road salt is used in winters.
snowsquirrel is offline   Reply With Quote
Old 09-29-2016, 11:05 PM   #420
kanaga
I got my replacement bolts through the dealership.
Old 12-13-2016, 01:16 PM   #421
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Does anyone have a copy of T-SB-0078-12 ?
Old 12-13-2016, 08:13 PM   #422
T-SB-0078-12.pdf
Old 12-13-2016, 08:35 PM   #423
NYC-SE
NYC-SE's Avatar
Thank you Scott. I had a sneaking suspicion you would have it.
Old 01-13-2017, 11:52 AM   #424
fourbangingfun
fourbangingfun's Avatar
Just got around to replacing my control arm bolts.
2007 sedan with 180k miles on it. 10 years of exposure to Massachusetts' wintry conditions. They salt the living Jesus out of even the most slight winter precipitation here.
Pretty decent amount of rot on the neck of the bolt. Surprisingly my mechanic said the control arms themselves are doing alright.
fourbangingfun is offline   Reply With Quote
Old 01-13-2017, 11:58 AM   #425
tmontague
tmontague's Avatar
Good thing you got them out when you did, mine looked about the same when I removed them 2 years ago
Old 01-13-2017, 01:50 PM   #426
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
How concerned do you think us California kids have to be about this?
On Instagram
On Wheelwell
Old 01-13-2017, 02:40 PM   #427
tmontague
tmontague's Avatar
not very likely unless you live near the coast with a lot of ocean spray.
I'd swap them at the 10 year mark if I lived in Cali. Or to save money just pull your out and coat the threads with anti seize and then coat the whole thing in marine grease. That's what i did to my new ones and after 2 years not a single thing of rust on the bolt shaft
Old 01-13-2017, 03:22 PM   #428
ern-diz
ern-diz's Avatar
Thank you, sir!
On Instagram
On Wheelwell
Old 01-27-2017, 05:02 PM   #429
RichardPan
Drives: Toyota Yaris 2007
My 07 sedan is now 10.5 years old, and I live in Ottawa, Canada, where road salts are just a fact of life. Would it be a good idea to find a mechanic to replace the bolts, before it snaps? Seems like this potential problem would be the last remaining item that would limit the service life of my Yaris. It has only 130k km on it, and engine/transmission seems to be in good shape.
RichardPan is offline   Reply With Quote
Old 01-27-2017, 08:17 PM   #430
ex-x-fire
I'd soak those bolts in lube before trying to remove them.
Old 01-27-2017, 08:48 PM   #431
tmontague
tmontague's Avatar
The issue is accessing the threads to get a penetrating lube in there.
If you have impact tools if try yourself, if they snap drive cautiously to the nearest mechanic. If you don't have impact tools then just go to a mechanic.
I can't remember but I believe the solution if they snapped was to have a bit welded onto the stud which can then be removed.
Old 04-20-2017, 07:00 PM   #432
NYC-SE
NYC-SE's Avatar
Still a problem with 3rd gen cars
This is still an issue with 3rd gen cars. Below is a pic of the passenger side LCA bolt from my 2014 SE. I changed them out a week ago because the front end was making a clunking noise and I suspected that the LCA bolts were the issue. They were. No more clunking now. You can read about my adventure here:
http://www.yarisworld.com/forums/showthread.php?t=57576
For those who suspect this may be an issue with their car: The only symptom I had was the clunking noise. The car rode, handled, steered, braked fine. Everything that you could see of the front suspension looked fine too. That's the problem, the LCA bolts are hidden. If you are in a heavy salt area and you are clunking you need to check the LCA bolts.
I was able to R&R the bolts with the car on the ground without a problem. As others here have suggested I coated the new bolts with a high quality calcium sulfonate marine grade grease before installing them. Should help for the future, but I'll be inspecting them every year going forward.
Toyota needs to update the TSB to include ALL model years and they need to extend the warranty on this to 3rd gen cars as well.
P.S. This thread needs to be made a sticky.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
