Old 02-22-2017, 09:17 PM   #1
swv9
swv9's Avatar
Drives: Toyota New Yaris Sedan GLI 201
Pressure tires 205/50 r15
Hi friends
I need to know how much pressure I could use in my tires ContiPremium Contact 2 05/50 R15... (before I have 175/65 R14, changed by R15)
I have a New Yaris Sedan 2013 GLI
Thanks, regards from Chile
Sorry for my english
swv9 is offline   Reply With Quote
Old 02-23-2017, 08:20 PM   #2
SirDigby
Drives: 2007 yaris 3 door
it does not matter the size. pressure is pressure.
the question is, what is your altitude?
sea level pressure is 30psi
3000 ft. (1000m) is about 32psi
5000 ft. (1500m) is about 33-34psi
7000 ft. (2100m) is about 34-35psi
10000 ft. (3050m) is about 36psi
Old 02-23-2017, 08:26 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
30psi? It really depends on the tire. I run Yokohama s.drive tires and they really need 35-38psi to wear evenly. And I'm almost at sea level.
Old 02-23-2017, 08:51 PM   #4
swv9
swv9's Avatar
I am in Los Andes city, Chile... 819m aprox
https://en.wikipedia.org/wiki/Los_Andes,_Chile
Old 02-23-2017, 08:51 PM   #5
Rigaud
Drives: 2009 Yaris
Oh boy.......YES tire size makes a difference. The bigger the less psi is required to a certain extent.
I run 205/45R16 with 30-31psi front and 26psi rear. I usually make a chalk marl on the sides and drive the car on and off highway then look at the wear mark off the chalk. I then adjust accordingly + or -.
Old 02-23-2017, 08:52 PM   #6
swv9
swv9's Avatar
so?
I think the pressure depends more on the vehicle than on the tire or not?++
Because if a tire of a measurement, I use it in different cars, the weight changes therefore another pressure
Old 02-23-2017, 11:00 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
http://blog.toyota.co.uk/toyota-tyre...and-size-guide
http://www.puretyre.co.uk/toyota-tyre-pressures/
Old 03-01-2017, 08:43 PM   #8
SirDigby
I was just starting with the door sticker setting and adjusting for loss of pressure due to altitude, but temperature and humidity can also make slight changes. here's a chart:
Winter tires and road hazard program w/Tire Rack mikey4226 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-04-2012 11:07 AM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Boring Tires Recommendation DaveG Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 07-16-2010 04:18 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
