Old 04-17-2017, 03:11 PM   #1
Pinchlite
Drives: 2007 yaris HB
Rear brake cylinder end cap fell off during brake shoe swap.
While replacing shoes one end of the cylinder fell off.I quickly slid back on and nothing leaks(Dont think they are original
(Nothing hit the ground or got dirty/contaminated)
They have a rubber seal with spring inside so not sure if i need to bleed?
for a first drum pad replacement all went well,besides some frusturating moments of course
I took for drive and all feels fine,should I leave as is?
Pic of what came off(Before pic)
http://i.imgur.com/y9mMWmj.jpg
Old 04-17-2017, 04:21 PM   #2
You are fine. That just keeps the piston from becoming contaminated with dirt and grime.
Old 04-17-2017, 04:56 PM   #3
Pinchlite
So the cap comming off,spring popping out some oil leaking then putting cap/spring back on/in is fine?
If so then no worries.
Thanks.
Old 04-17-2017, 06:42 PM   #4
CoryM
Drives: 2009 5-door, 5-speed
The piston came out and you likely have air in the system. Time to bleed out that corner. It is possible that you have damaged the piston seal, but probably not. After you are done bleeding, have your helper hold steady pressure on the brake pedal as if they were coming down to a hard stop. Make sure you have no fluid coming out, and the pedal height remains the same while doing this pressure check.
With brakes, pretty much any time you see brake fluid come out, you should bleed.
Cheers.
Old 04-17-2017, 08:22 PM   #5
Pinchlite
Cheers.
I will try and find out how to bleed corner that cap fell off.
Once I put cap back on and wiped down I pushed in the 2 end pin things a couple of times and nothing leaked out,but yes I will have to bleed.
Hopefully its okay to drive like this because I wont have time till weekend.
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 09:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 07:05 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-26-2007 12:10 AM
