Old 06-08-2017, 03:57 PM   #1
sven337
Drives: Yaris
Dirty cabin filter installed backwards broke air conditioning?
Hi,
while I was doing something else on the car, I figured I would check if the cabin air filter needed to be replaced. It did, and until I could get the new one I reinstalled the dirty one (after having shaken it a few times outside to kick off as much crap as possible). Unfortunately, I installed it backwards, and I suspect it may have broken my air conditioning.
I wasn't in the car when it happened, and the person driving wasn't very technical - what they told me was that as soon as they turned on AC ("normal" ventilation worked fine), they saw "white smoke" come into the car. That smoke was apparently odorless, and stopped after a few seconds. When asked, they said they had no idea whether it could be condensation or real smoke.
Since then, the AC still works (without any white smoke), as you can feel cold air being blown inside the car, but it definitely doesn't work as well as it used to - the air is cold, while it used to be *very* (exceedingly) cold. With summer being on us soon, I'd like to have AC that works well.
I assume that some of the particles stuck in the filter were sucked into the system where they caused *something*. Any idea as to what that something may be, and how I can fix it?
Thank you
sven337 is offline   Reply With Quote
Old 06-09-2017, 06:02 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
HVAC filter backwards smoke condensation drain tube
Was the removed backwards-installed filter element intact? Check for blocking inside the HVAC drain tube.
Old 06-09-2017, 06:13 AM   #3
sven337
Drives: Yaris
The filter was intact, but dirty.
Can you help me find the HVAC drain tube?
Thanks
EDIT: I should do my homework first. https://www.youtube.com/watch?v=AmeQiOrHFug and a multitude of results come up. I'll try that and report back.
EDIT2: The HVAC drain tube was not clogged. I ran the AC for a while, cut the engine, and didn't see anything come out though, so maybe there's a clog somewhere else in the system. Suggestions welcome.
Old 06-12-2017, 11:16 AM   #4
soldiersvejk
Drives: 2009 Toyota Yaris Sedan
As far as to my knowledge,it is not impossible to clog the "AC" line, if you mean where the refrigerants flow.
I could only clog the drain plug of the evaporator, or some fins within the evaporator. However, since the debris collected by the cabin air filter are often relatively small, they are not more likely to causing clogs than the leaves near your air intake between the windshield and the good.
soldiersvejk is offline   Reply With Quote
Old 06-12-2017, 01:44 PM   #5
CoryM
Drives: 2009 5-door, 5-speed
There isn't much damage the backward air filter could cause. Worse case it may have let more grit get into moving parts such as your fan bearings etc. These are designed to run w/o a cab filter, so you likely didn't damage anything.
The white smoke may have been dust from them using the fan in recirc for the first time and blowing the dust out of the backwards filter?
A/C refrigerant has dye in it and smells pretty strong so I doubt that is what they noticed. And the A/C wouldn't work at all now if the gas came out. Is it possible your A/C wasn't working well prior to the "smoke", and you just noticed now because your attention was drawn to it? Also, with the A/C and engine on, look underhood and see if the A/C compressor is actually engaged and spinning.
Old 06-19-2017, 05:38 AM   #6
sven337
Drives: Yaris
It is possible that A/C wasn't working too well and that the "smoke" just draw attention to it. That happens often in life. :)
I read, somewhere on this forum, the suggestion of running the blower at full speed with A/C and the vents closed. I did that for a while after having trying to unclog the drain tube (which I don't think was clogged).
It looks like that operation did recover some A/C "performance". It's still not blowing air as cold as it used to, but it can be considered functional. I guess a 10 year old A/C unit that hasn't undergone any maintenance/replacement can plausibly not perform as well as a brand new one.
Tags
air conditioning, cabin filter
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 05:00 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
cabin air filter kaboom DIY / Maintenance / Service 108 03-31-2009 09:00 PM
DIY: Changing Your Cabin Air Filter tk-421 DIY / Maintenance / Service 0 06-30-2007 06:40 PM
CA: Free Cabin Air Filter, Socal only. kunfuzion Items for Sale by private party 6 03-24-2007 11:34 PM
