Drives: Toyota Yaris Hatchback 2009 Join Date: Aug 2017
I have an 09 Yaris hatchback. To the right of the emergency brake in the center console there are four accessory ports. Currently I have a factory installed aux port and automatic dork locks taking up two of them. The other two are empty. I want to install a USB port in one of the empty blanks to use for charging (NOT for music).
I've found an oem dual USB port charger for use in Toyota cars that I can tell is made for the ports in my car, but do not know how to go about installing it properly, and after extensive searching for help videos/articles online with no avail, I've come here for assistance. Any help or suggestions would be appreciated. From the look of the item, I think it's a simple red/black (hot/ground) wiring solution but I'm not sure. Thanks! The USB charger can be seen here: https://www.ebay.com/itm/252574886831 |
Hmm, I see...
Drives: 2012 Toyota Tundra and Yaris Join Date: Oct 2016
if you want it to only be on, find a constant hot or run directly to the battery (install a fuse). If you want it to only be on when the key is in, find an acc wire and tap in
"Everything happens for a reason. Sometimes that reason is you're and idiot"
![]() ![]() Drives: 2007 Toyota Yaris 3dr Join Date: Aug 2017
I'm going to attempt this mod as well. It could be convenient to install a usb charging station there with a short plug since phones could fit in the rectangular opening near the brake.
The Gibbs Garage 2016 Lexus GS350 f-sport (my main car) 2013 Lexus RX350 (wife's vehicle) 2010 Toyota Tacoma (my second vehicle) |
![]() Drives: 2010 Yaris Liftback A/T Join Date: Aug 2015
Did anyone attempt this? can you post pics / a walk through of how you did it?
![]() ![]() Drives: 2013 yaris Join Date: Sep 2014
Diy Bump
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
No pics but easy install.
Remove center counsel. One bolt and I removed shift knob to get it out of the way. I ran ground wire to one of the bolts under counsel. The other went to the radio accessory wire (pink?). I bought on ebay a usb port that was made for Toyota. It had two blue leds in it. Fits fine, looks neat when lit, good quality and it's fused. All for less than $5 USD. |
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg Join Date: Sep 2017
I need one too,should be easy enough
If it wasnt for my modesty ,i would be perfect !
| Tags |
| charger, install, phone charger, usb, usb port |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 09:47 AM |
| Is there a center console available for 2015 Yaris Hatchback? | OGHUGO | Third Gen Yaris General Discussion | 16 | 12-18-2015 05:23 AM |
| Steps to install a subwoofer in Yaris 2008 HB | eepp | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 11-20-2013 08:30 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
