Old 04-22-2009, 12:04 PM   #19
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
Giupo,
I'm currently using the E-Manage Blue for my turbo, and the MAF volt is clamped at 4.95v.
Do you have a MAP sensor as well? If budget permits, you may want to add a MAP sensor as another input for your Ultimate and tune your car off its reading as well. You can achieve a much more accurate tune with a MAP sensor rather than relying on the TPS readings. But in your case, you have the boost harness as well, which is cool.
If you don't want to go standalone but yet you want to remove the MAF altogether, you could consider using the HKS F-CON V Pro. It allows you to remove the MAF physically.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 04-22-2009, 04:56 PM   #20
Giupo
Drives: Yaris
For CTScott
Excuse me but my MAF arrive at 4.9v..Thank you very much
Giupo is offline   Reply With Quote
Old 04-22-2009, 05:01 PM   #21
Giupo
Drives: Yaris
Originally Posted by changchewsoon View Post
Giupo,
I have the Greddy E-manage Ultimate and use the Greddy sensor pressure..I can eliminate the maf with this greddy ecu but I need the Maf value..
Old 04-22-2009, 05:04 PM   #22
Originally Posted by Giupo View Post
For CTScott
If I understand correctly, it goes up to 4.9v, but the clipping starts when it is at 3.94v?
Old 04-22-2009, 05:44 PM   #23
Giupo
Drives: Yaris
ok, the maf sensor arrive at 4.9v at 6000 rmp but at between 4000-5000rpm the Maf value 3.94v I avvert the slightly engine brake but the A/F ratio is good..
Old 04-22-2009, 05:56 PM   #24
Tomorrow I will have time to connect a voltmeter to mine and see what a normal one reads at various RPM. I suspect that it will follow with the 0.4 to 2.2 normal operating range.
The question is why does yours clip between 4K and 5K, but then stop clipping above that?
Old 04-23-2009, 09:16 AM   #25
Giupo
Drives: Yaris
I don't know because the maf clip between 4000 and 5000 Rpm, before 4000 rpm e after 5000 rpm the engine is good... I suppose that between 4000 and 5000 Rpm the engine is at max of Tourque.
Old 04-23-2009, 10:41 AM   #26
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
the turbo is most likely flowing the most volume of air at the RPM and maxing out your MAF.
do you have any datalogging showing your MAF logs based on load and RPM?
Russelt3hPirate is offline   Reply With Quote
Old 04-25-2009, 04:25 PM   #27
Giupo
Drives: Yaris
Hi Guys :)
*The problem has been resolved* The maf clip because it was too much near the turbo downpipe and the heat annoyed the Maf sensor. I have moved the Maf support more near the air filter and the problem has been resolved :)
picture before the support maf moved:
Old 04-25-2009, 08:40 PM   #28
Hi Guys :)
I'm glad to hear it's resolved. Excess heat makes a lot of sense for what was happening.
Old 04-26-2009, 10:27 AM   #29
Giupo
Drives: Yaris
Thank you very much :)
Old 04-27-2009, 12:15 AM   #30
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Hi Guys :)
Great to hear it was fixed I'm assuming that turbo kit is full on custom? Do you have anymore pics?
Old 02-07-2017, 11:29 AM   #31
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Bump... I never noticed this thread. Might be useful.
Old 09-06-2017, 10:33 AM   #32
Bluevitz-rs
I'm getting this same problem. Has anyone ever data logged the MAF voltages on a NA engine?
I'm getting clipping at random RPMs but I did a log and if I floor it, the MAF spikes to 3.9V and that's when the hiccups occur. This can be anywhere from 2000 to 5000 RPM. Odd thing is, the MAF will still read all the way up to 4.4V without any hiccups sometimes.
Old 09-08-2017, 09:22 PM   #33
kou
Drives: 08 lb
Are you using aem fic or greddy e manage?
Old 09-08-2017, 09:48 PM   #34
Bluevitz-rs
FIC
I haven't tried building a MAF voltage table yet. Haven't had time.
Old 09-08-2017, 11:00 PM   #35
kou
Drives: 08 lb
FIC
Only maps you should be using are the o2 and fuel maps. Maf clamp is in the setup menu and should be set at 4.95. unless you have the maf in a bigger or smaller pipe that is what the maf table is for. aem does not really go over this and it causes alot of people problems.
Old 09-11-2017, 09:17 AM   #36
Bluevitz-rs
I have it set to 4.9v. The problem is I can get it to produce 3.9V at as low as 2000 rpm. I'm thinking the computer sees this as a problem and cuts ignition or fuel.
The MAF table allows you to set the voltage output based on the voltage input.
So you can have it read exactly as it should up to the point where the turbo starts drawing in more air than a NA engine would and makes it freak out, clamping the voltage at a set RPM.
I've had this problem even before I had an FIC installed. I've even run the car without the O2 sensor hooked up and just the FIC making fuel adjustments.
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
$2500 Turbo Kit is back to life! bdc87 Forced Induction Forum 8 10-20-2008 10:46 AM
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 03:02 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
