Old 09-23-2017, 02:44 PM   #19
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
Originally Posted by enviri View Post
nothing, really. you might prefer a more front bias again and get an SE brake booster and proportioning valve, but really isn't needed. (i seem to forget if there's something else under the hood related to that booster area)
setup as is, the swap will make your rear brake pad last as long as your fronts.
pads are like what 26 a piece if you go non oem.
Sent from my LG-H918 using Tapatalk
DarkShadowFox is offline   Reply With Quote
Old 09-23-2017, 05:57 PM   #20
SirDigby
Drives: 2007 yaris 3 door
changing shoes in a drum is not that bad, if it ever needs to be done. my last car went 338,000 miles on the factory shoes when i sold it. i had purchased them 3 times, and returned them to the store 3 times. shoes last forever if the wheel cylinders do not leak. that is the best benefit. (fronts were serviced/replaced 5x in that time frame)
disks looks pretty, but they require 3x the maintenance...
Old 09-23-2017, 07:13 PM   #21
hairygityeti
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg
I was toying with an axle swop when my rear bearings went but i went with new bearings in the end. UK is easy for cheap Yaris spares at this moment in plentiful supply so im lucky with my 1st gen Yaris S the old .rust bucket lives
If it wasnt for my modesty ,i would be perfect !
hairygityeti is offline   Reply With Quote
Old 09-23-2017, 09:01 PM   #22
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
338,000 miles? Makes me think they weren't adjusted properly.
Old 09-24-2017, 12:09 AM   #23
enviri
enviri's Avatar
Drives: 2010 Yaris
lol my drum shoes were at 2mm before axle swap..i think it was like 40k miles hahaha. Blame ny traffic?
Old 09-24-2017, 12:27 AM   #24
IllusionX
Drives: 07 Yaris Sedan Aero
Yeah, I went 90k miles with mine. About 165k km. Had about 2mm left and only ajusted them twice in its life time. 8 years.
I wonder how long the new ones last. I'm having them adjusted every other year now. And the front brake serviced. They have never looked so great before.
I used to never touch them until they need to be replaced lol
Sent from my SM-G930W8 using Tapatalk
Old 09-24-2017, 10:54 PM   #25
SirDigby
i adjusted them every time i replaced the front pads/rotors. i would even buy a set of shoes. they looked good; i'd clean the drum/springs,adjuster and scuff up the contact surface, and adjust the drag and return the shoes to the store. the contact material is 4mm new. i did a lot of highway driving at the time, so the millage is not that fair. i drove the car often, and accumulated 338,000 over like 13 years...
Old 09-25-2017, 12:26 AM   #26
enviri
enviri's Avatar
Drives: 2010 Yaris
all the more reason to think about rear discs...just glance at the rear pads and rotors and go about your business :P
rear beam question: one wheels sticks out more DINOeggxo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 58 05-10-2014 11:38 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 06:02 PM
