Old 10-09-2017, 11:00 PM   #19
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
Just to clarify, the DRL position actually will run the low beams at a reduced output. Some of the SE models had the LED DRLs so you'd also need whatever makes that work to use these lights as intended.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 10-09-2017, 11:05 PM   #20
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Probably a load resistor of some kind, I imagine. In my car, I know the DRL position runs the low beams at regular voltage compared to full on position. I tested the output voltage in both switch positions when I decided to put LED bulbs in the factory housings to replace standard halogen H4 bulbs.
m.flores.0928 is offline   Reply With Quote
Old 10-10-2017, 12:23 AM   #21
IllusionX
Drives: 07 Yaris Sedan Aero
The power is actually pulsed, so the bulb gets full 12v, but not the current it needs for full intensity.
I have my DRL wired as my fogs, with a cap, so the replay doesn't see the pulsed current on my 07.
I could wired it with any lights I want, but I was just lazy to fish wires through the firewall.
Old 10-10-2017, 03:06 AM   #22
m.flores.0928
Drives: 2014 Yaris
Oh I see. Good to know, thanks
Old 10-10-2017, 11:20 AM   #23
DarkShadowFox
Can I get the parts # for the Hybrid headlights.
I need them for my current project.
also can I get a diagram on how to install them, I currently have DLRs so its just switching the connectors around?
Thanks.
Old 10-10-2017, 12:40 PM   #24
m.flores.0928
Drives: 2014 Yaris
Thanks.
Part numbers would be amazing.
I don’t have any diagrams, unfortunately. Perhaps someone else could chime in?
Old 10-10-2017, 03:39 PM   #25
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Thanks.
If its for your 2015 you Can buy the headlamps with LED drl as aftermarket now.
http://www.ebay.de/itm/Scheinwerfer-...QAAOSwVaVZyk10
http://www.ebay.de/itm/Scheinwerfer-...gAAOSwqU5Zyk10
On the facelift there is no difference between normal and hybrid headlights, there is also High spec non hybrid models with LED DRL on the European market.
Also in the US
http://www.ebay.de/itm/Toyota-Yaris-...gAAOSwY~VZccKH
Part Numbers for pre facelift Can be found Here.
http://www.japan-parts.eu/
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 10-10-2017, 03:43 PM   #26
DarkShadowFox
Also in the US
those are not the european hybrid lights. those are the Se lights
Sent from my LG-H918 using Tapatalk
Old 10-10-2017, 05:28 PM   #27
stykerdk
Hybrid an non hybrid facelift has the same headlights only High spec facelift hybrid has LED DRL.
This hybrid has not
https://images.autouncle.com/da/car_...trinl-gear.jpg
And this is with LED
http://www.autosanterno.com/sites/de...IMG_2750_0.JPG
Old 10-10-2017, 05:28 PM   #28
DarkShadowFox
This hybrid has not
hes asking about the 2014 ones pre facelift
Old 10-10-2017, 05:43 PM   #29
m.flores.0928
Drives: 2014 Yaris
Thanks.
Apologies, I misread your comment. I thought you said you have part numbers.
I have part numbers now for pre-facelift hybrid headlights (and tail lights) with LED DRL, see below. I also included USA spec headlight and tail light part numbers to compare, also pre-facelift. Google the part numbers for images of the lights.
hybrid headlight, LHD, left side
81170-0D500
hybrid headlight, LHD, right side
81130-0D500
hybrid tail light, left side
81561-0D390
hybrid tail light, right side
81551-0D390
USA headlight, left side
81170-52D30
USA headlight, right side
81130-52D30
USA tail light, left side
81561-52760
USA tail light, right side
81551-52820
Old 10-11-2017, 02:09 PM   #30
DarkShadowFox
Hello 534 dollar a light plus shipping.
I wish they had the black housing ones from the Active. do you have those part #'s ?
theres a silver capped one and a black capped one.
im picky but I have black housing lights now so Im just trying to avoid that ugly piece of silver.
will take it if I can but if you could take a quick look for me :D ?
Old 10-11-2017, 02:36 PM   #31
m.flores.0928
Drives: 2014 Yaris
yea, OEM parts are expensive. Especially for the yaris because there is a tiny aftermarket, especially especially because these parts are not original to USDM so of course they're 500+ each corner, unfortunately
my initial post had an eBay link with the black bezel lights, but I didn't find a part number. I'll keep snooping.
Old 10-11-2017, 02:41 PM   #32
stykerdk
They are for sale here in Poland 124US dollars for a pair of hybrid headlights.
http://allegro.pl/toyota-yaris-iii-l...id=201#thumb/3
But i cant read polish, so you may try to contact the seller and hear if they can ship to the US.
And one more set
http://allegro.pl/lampa-lewa-prawa-r...rs_rule_id=201
There is many for sale in Poland
https://allegro.pl/kategoria/lampy-p...p-aut-1-5-1003
Old 10-11-2017, 02:46 PM   #33
m.flores.0928
Drives: 2014 Yaris
And one more set
I translated the web pages using Chrome, it appears that they are priced per housing, not per pair. Its hard to tell, the translation was pretty rough. It said "The price is 1pc / page", whatever that means.
In any case, good to know! Thanks for sharing
Old 10-11-2017, 03:00 PM   #34
stykerdk
If you click on the items most sellers have contact info with email and phone number.
I think its better to contact the sellers direct.
There is 7 pages when you search yaris+LED
https://allegro.pl/listing?string=La...p-uni-1-5-1003
Old 10-11-2017, 03:01 PM   #35
m.flores.0928
Drives: 2014 Yaris
This link works really well for tracking part numbers if you understand what you're looking for and how the site works.
Old 10-11-2017, 03:03 PM   #36
m.flores.0928
Drives: 2014 Yaris
Great, thanks!
Tail light parking light & license plate stop working SIRAY2 General Yaris / Vitz Discussion 1 06-03-2017 03:59 PM
Tail light from 2009-2011 hatchback on 2006-2008 body. alexistecnico Cosmetic Modifications (Exterior/Interior) 2 05-05-2017 02:39 PM
FS: Various Parts from a 2009 Yaris Hatchback Freestylin Items for Sale by private party 17 02-24-2016 10:36 PM
Stock headlight and taillight for sale GabL Items for Sale by private party 11 04-14-2014 09:24 PM
FS: 09LB Bumper, Taillight, HeadLight, Side Mirror, parts, etc.. AlainMikli Items for Sale by private party 27 05-17-2010 11:04 PM
