Old 11-19-2017, 05:45 PM   #1
ex-x-fire
easy warm air intake
I did a warm air intake today, the snorkel on the air cleaner housing pops off and leaves you with a section of 3" tubing, so you can slide on the duct right there. I ran it over the valve cover to a piece called a saddle vent. I wedged this onto the exhaust manifold. I don't think I'll need to bolt it down as its fits pretty good.
File Type: jpg MFX38_MFX48_MFX58_MFX68_MFX88X_Master.jpg (21.6 KB, 200 views)
Old 11-19-2017, 06:44 PM   #2
ex-x-fire
Here's some pictures.
Old 11-19-2017, 08:06 PM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
And why?
Old 11-19-2017, 08:56 PM   #4
tmontague
tmontague's Avatar
This post goes well with the muffler bearing and blinker fluid videos on line. I seriously don't know if you're just screwing with us or not...
Old 11-19-2017, 09:40 PM   #5
Jeanseb29
Drives: Toyota Yaris RS 2011 (HB)
Wtf
Sent from my SM-N910W8 using Tapatalk
Jeanseb29 is offline   Reply With Quote
Old 11-19-2017, 10:32 PM   #6
ex-x-fire
I don't know about you guys, I see a pretty big change in fuel economy during the winter. I know some of it from the fuel additives, but most of it is from the cold air. While its great for power it really impacts fuel mileage. Its something I won't use in the summer.https://en.wikipedia.org/wiki/Warm_air_intake
Old 11-20-2017, 01:10 AM   #7
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Warm air should effectively reduce fuel consumption, but too hot will cause detention and cause the timing to pull back, greatly reducing power and fuel economy.
Old 11-20-2017, 09:33 AM   #8
tmontague
tmontague's Avatar
The theory is the ecu reduces fuel when the intake air is warmer as the air is less dense so it needs less fuel for combustion.
Although most of that is true all this does is reduce engine power. So there is zero increase in efficiency you just effectively reduce power. This makes you need to give more throttle to do the same work which negates any benefit.
In such an efficient engine as the 1nz you just need do have a lighter right foot and you'll get excellent mileage. You are not limited in mileage with this car due to engine size and fuel demand, you are limited simply by the driver themself and how they choose to drive.
Old 11-20-2017, 12:02 PM   #9
**duct
Old 11-20-2017, 04:38 PM   #10
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I would do nearly the exact identical thing during winter time for mpgs.
The results were typically 3-4mpg gains from this mod. Back when i liked getting over 50mpg average for a tank.
Now I dont care anymore and dont hypermile like I used too
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 11-21-2017, 03:09 PM   #11
komichal
Oh yes, thousands of engine specialists on highly paid development workplaces are daily introducing complex, bizzar solutions to improve the mpg thus reduce the emissions... and nobody came up with an idea of heat-hose. They are all nothing but a bunch of losers! :D
Old 11-21-2017, 08:18 PM   #12
malibuguy
Obsessed with 1.5L
The ignorance is strong with this one
-96 Tercel 4dr
Old 11-21-2017, 09:11 PM   #13
Bluevitz-rs
Clearly they've never seen a carborated engine with a factory hot air pipe that draws off the heat shield.
Old 11-22-2017, 03:51 AM   #14
komichal
I used to have such a car. But we are talking about Yaris and "a bit" different engines these days.
Old 11-23-2017, 03:06 PM   #15
ex-x-fire
I scanned the car last night, the air temp was 27*f, after starting and running for a minute the IAT was reading 60*f. Going down the road it bounced between 45 and 60*f before settling at 53*f. At stops it would go up 70-80*f. If anything it'll save gas when idling in snowy days.
Old 11-23-2017, 04:22 PM   #16
Mickman
Drives: 2006 Yaris RS
I just lol'd
Mickman is offline   Reply With Quote
Old 11-23-2017, 04:43 PM   #17
tmontague
tmontague's Avatar
it will likely help at really cold starts, a lot of fuel around here is used on the crazy cold mornings
Old 11-24-2017, 05:29 PM   #18
komichal
It will not help anyhow. Cold start means that the exhaust pipes are also cold, so is the air. Before it heats up significantly to get into the pipe and all the way through the frozen airbox then the engine runs already so hot that the air temperature is insignificant.
Cold Air Intake... I PHANT0M I General Yaris / Vitz Discussion 2 01-31-2012 03:22 PM
The great intake debate! fmicle General Yaris / Vitz Discussion 74 10-07-2009 12:37 AM
guess what I'm waiting for and how much I paid? Ric n Sov's Vitz RS General Yaris / Vitz Discussion 27 06-27-2007 08:36 PM
