Drives: 1 Join Date: Aug 2017
Off-road build
Hello I have a 2015 Yaris le (North American) and I was thinking what my best bet would be for an off-road build. I have 17 inch work emotion wheel but was thinking of going 15 inch with a nice fat tire. What about lift ? Barely any info on lift kits , I'd like a little more clearance. I would be doing light off-road nothing crazy.
![]() Sent from my Moto G (4) using Tapatalk |
![]() ![]() ![]() Drives: 2014 Yaris Join Date: Feb 2017
I’m curious too about this so I’ll follow this thread. I have no info about off roading these, but I do have some questions about your car here.
How did you tint your headlights? Did you paint or wrap your hood? Looks good though! Sent from my iPhone using Tapatalk |
OEM scion xd springs would likely lift it a bit
I lifted my echo on oem first gen scion xb struts/shocks
![]() ![]() ![]() ![]() ![]() Drives: 2016 SE Join Date: Nov 2015
i like the black hood look
There are several off-road Yaris' and associated threads here on the forum, but are you really planning on going from that very attractive street machine to a grungy, off-roader?
It's just my opinion, so take it for what it's worth, but your car looks fantastic. Turning it into an off-roader would be a travesty. Edit: Found a few old threads, but it looks like the image links are broken. http://www.yarisworld.com/forums/sho...ht=road&page=2 http://www.yarisworld.com/forums/sho...light=off-road Last edited by ern-diz; 01-04-2018 at 02:54 PM. |
#7 | |
But, yeah, I personally couldn't do that to that car. IMO, it's way too nice. If I was inclined, I'd go buy another similar but not quite so nice version and off-road it. That said, I'll likely never own that nice a Yaris. Although I could afford a new one, I'm too cheap and enjoy working on older ones.
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
Sub'd!
^^^ So much good stuff on SubCompactCulture and YarisWorld.. ![]() Dig those wheels too man - going to make a note of those for when I get around to doing wheels and tires. -- Adam |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Subcompact Culture: The Small car blog |
![]() ![]() Drives: Toyota Yaris 1.33 SR Join Date: Nov 2014
You could do something inspired to the rally version, something like this...
![]() But I would not touch your car, it's perfect as it is! |
rock crawler offroad gravel Yaris 2007
Photobucket blanked the mini-spare-out-front mock-up photo I posted here, but it is going to happen...for traction, flat cargo floor, and a resulting look I don't mind. Also want a second tow hook on the driver's side...two two hooks makes a tow-bar mount?
On the OP's late model, the spare might soften the visual effect of that huge grille. (Does that grille remove w/o pulling the whole bumper cover? prolly not.) Last edited by dogsridewith; 01-09-2018 at 07:26 PM. |
Hmm, I see...
Drives: 2012 Toyota Tundra and Yaris Join Date: Oct 2016
Nice! Im doing a rally style build with mine (got rear ended so haven't made progress). I like the XD idea, also I THINK that flat out suspension's kit can be used to lift it. not sure, but im sure you can call and go over specs with them
https://www.flatoutsuspension.com/products/sryaris
"Everything happens for a reason. Sometimes that reason is you're and idiot"
the 2 door looks great with the black wheels
| silly off road build. | hairdresserscar | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 02-21-2014 12:45 AM |
| Dirt Road Yaris | carlghoul | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 10-16-2011 07:22 PM |
| Yaris Off Road??? | Rutherfordman | General Yaris / Vitz Discussion | 18 | 02-26-2010 11:13 PM |
