Old 05-11-2018, 06:35 PM   #1
DJman
Drives: Toyota Yaris 2012 Auto
Identify Cable behind front right wheel cover
Hello
Someone collide in front right of my 2012 yaris when I was parked.
The front bumber cracked a little, but the front plastic cover(arc cover) of the wheel and the plastic cover underneath the bumber cracked ,where the screws are, so I had to replace them.
My mechanic removed the and he ordered new ones.So I am using the car without these covers.
I saw a cable hanging, which was no where connected
Can anyone help me identify what is this cable for.
Should it be connected somewhere?
Thank you
DJman is offline   Reply With Quote
Old 05-11-2018, 06:50 PM   #2
DarkShadowFox
can you give me more photos.
Old 05-11-2018, 08:55 PM   #3
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
Looks like your fog light connector. If your model came without fog lights, the cable is still present. Would just cable tie it out of the way then.
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Old 05-14-2018, 12:01 PM   #4
DJman
I also think, it's a fog light connector, but I can't find it on the other side and
also my model does not have fog lights.
Old 05-14-2018, 12:15 PM   #5
Main feed for fog lights as part of the main wiring harness. Had your vehicle been equipped with fogs, then the two lights would have fed off of this connector.
Old 05-14-2018, 04:17 PM   #6
RicStyx
It will be there regardless if you had them fitted or not. The other connector will be well tapped up and hidden by your crash frame. I wouldn't worry about it unless you want to use them to wire in a aftermarket fog light or Drl kit. I work with a lot of cars and finding spare connectors is so common. It's cheaper to make one wire loom than a different one for each car.
Old 05-15-2018, 08:52 AM   #7
DJman
Thank you all for your answers. I am kinda relief ,because I thought it was some kind of ABS sensor near there.
WTB Front bumper cover Yaris/VItz 2004 RS/TS/TDR samipr Willing to Buy by private party 0 12-06-2016 02:12 PM
How to remove wheel well cover properly........ Yawesh DIY / Maintenance / Service 1 03-17-2009 11:22 AM
rattles (front of steering wheel) wushumasterku DIY / Maintenance / Service 37 09-11-2007 12:24 AM
How can I cover front license plate hole hans_fh General Yaris / Vitz Discussion 13 01-03-2007 01:58 PM
question, do I need my hubs protected by a wheel cover foober Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-28-2006 01:25 PM
