Old 05-14-2018, 12:59 PM   #1
scylla
Drives: 2015 Yaris L
Brake bleed sequence
I will be using the upcoming weekend to do a full brake system flush. Does having a newer Yaris with ABS, stability control, ect change the brake bleed sequence from the usual RR,LR,RF,LF ?
scylla is offline   Reply With Quote
Old 05-15-2018, 02:04 AM   #2
CoryM
Drives: 2009 5-door, 5-speed
It will work fine in the sequence listed.
Cheers.
Old 05-15-2018, 03:03 AM   #3
scylla
Thank you.
Old 05-18-2018, 10:28 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
usually just start the furthest away from the master cylinder and work your way closer.
Old 05-18-2018, 11:17 AM   #5
tmontague
tmontague's Avatar
And if you have a m/t I would recommend bleeding the slave cylinder in between bleeding the r front and l front brakes
Old 05-19-2018, 12:24 AM   #6
zoidberg444
zoidberg444's Avatar
That's how i do it. Clutch slave cylinder last.
UK to Nordkapp in a Yaris
Old 05-19-2018, 08:00 AM   #7
bronsin
bronsin's Avatar
Right it’s probably more important to bleed the clutch slave One see year that it is the breaks.
For the experts only! My Honda ST 1300 has linked front and rear brakes via a Rube Goldberg nightmare of break plumbing. There is actually a secondary master cylinder attached to the left front brake caliper that applies the rear brakes when fraction from the rotating desk activate it. There’s like a 20 step leading process in the service manual. Which you are warned must be followed to the letter! But because parts of the system don’t work on my motorcycle I hop skip and jump around the procedure all the time without any problems.
I’m not saying don’t file the Publish sequence, just that if you experiment heal fine it’s not necessary.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
Hiss or pfft when pressing brake pedal kwk442 DIY / Maintenance / Service 3 06-03-2017 07:10 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 09:05 AM
brake bleed sequence Yarflana DIY / Maintenance / Service 1 03-08-2013 01:15 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 08:34 PM
