Old 09-14-2018, 06:39 PM   #1
inkfromblood
Hazards / Signals Not Working
Simply put, my turn signals and hazards do not work.
(2007 liftback)
I checked all the fuses - under dash, and under hood.
And all seemed to be OK.
I pulled the flasher relay, and it looked fine so I put it back.
(unless i missed something but there wasn't much to look at)
I checked the rear signal bulbs and they looked to be seated fine.
I looked for any loose wiring or connections and couldn't find anything.
I recently JUST had the bumper replaced from being rear-ended very lightly.
(It had just snapped a couple of the tabs that hold on the bumper)
However, the past couple of days have been fine after that repair.
I was also JUST backed into by a truck, putting a decent sized dent in the panel to the rear of the drivers side door (it just missed the door and the gas cap door). However, again, its been a day since that happened and the blinkers were fine last night and this morning.
Likely going to take it into a mechanic but I figured I'd check here see if I could DIY this over the weekend.
Thanks.
inkfromblood is offline   Reply With Quote
Old 09-14-2018, 11:06 PM   #2
jayeh
Drives: '08 Yaris LB
I had the same thing happen and it was one of the rear signal lights shorting out against the body (the lamp base had fallen out of the housing)
Maybe check that again?
jayeh is offline   Reply With Quote
Old 09-15-2018, 01:51 PM   #3
inkfromblood
Welp.
Spent 20 bucks on a new flasher relay, which did nothing.
I re-checked the rear signal bulbs. All seated fine, look good.
I removed and replaced the 10A gauge fuse, even though it looked fine and no change.
Even unplugged the battery for about 15 to reset the ECU.
Still no hazards or signals.
Everything else seems OK.
Old 09-15-2018, 02:08 PM   #4
barongan
Drives: m5
Stickied!
barongan is offline   Reply With Quote
Old 09-15-2018, 03:10 PM   #5
B.B._07
Drives: 07 5dr
Get yourself a decent cheap test light and check for power and ground, that way you can rule out one or the other. A test light will also let you test the fuses with 100% certainty.
https://www.amazon.com/ATD-5513-Heav...8-8&ref=sr_1_8
Also is the problem isolated to the rear of the car? If all the lights are out I'd suspect a grounding issue.
Old 09-15-2018, 04:22 PM   #6
inkfromblood
Thanks I'll get one of those for sure.
Its not isolated to the back. All signals / hazards are out.
But every other light on the functions fine.
Electronics randomly not working - NEED HELP! scoobopdan DIY / Maintenance / Service 5 12-17-2015 07:25 PM
Help! Turn Signals and Horn Stopped working kashanf DIY / Maintenance / Service 3 05-28-2014 05:20 PM
Projectors retrofit, black reflectors and dimmed front turn signals my2sense General Yaris / Vitz Discussion 11 06-20-2012 11:39 AM
Are rear red turn signals planned for Yaris as well ? 77W General Yaris / Vitz Discussion 38 02-22-2010 06:41 PM
