![]() Drives: 2016 yaris Join Date: May 2018
2016 HB doors won't lock with lock button
When I hit the lock button all the doors lock, and immediately unlock. This just started today.
Sent from my moto x4 using Tapatalk |
Using the key fob or interior lock button?
Interior lock button, I don't have any key fobs.
If I lock it with key from outside, it works.
If I push the lock to the locked position manually, it unlocks electronically Sent from my moto x4 using Tapatalk |
If I use the ignition, and move it from run to off, and while pulling the key out hit the lock button, it works. But if I hit it a second time it unlocks.
Maybe my issue is in the key hole Sent from my moto x4 using Tapatalk Last edited by JDJanitor; 10-19-2018 at 09:25 PM. |
Problem SOLVED
![]() I had plugged a small power Bank in to charge, it must have somehow supplied power backwards, because when I unplugged it, and hit the lock button it worked every time. I pulled every fuse I blew out all the switches, and ignition with compressor I must have hit the lock button over a hundred times. Sent from my moto x4 using Tapatalk |
| Doors Won't Lock | TutorMe | DIY / Maintenance / Service | 3 | 08-05-2014 03:04 PM |
| Shouldn't the doors lock... | imike929 | Third Gen Yaris General Discussion | 24 | 04-29-2014 09:28 PM |
| Radio stays on, doors won't lock | jtown | General Yaris / Vitz Discussion | 7 | 07-16-2012 09:53 PM |
| Yaris Key fob wont lock my doors! | Treeny | DIY / Maintenance / Service | 3 | 03-29-2012 07:27 AM |
| center console lock button | ryota | General Yaris / Vitz Discussion | 10 | 12-16-2009 01:34 AM |
