#379 |
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
Hi all
First time poster as well here after trawling through the site looking at 2zr threads :). I'm from Australia and it would seem nigh impossible to get my hands on the required brackets from a MT XD for a 2zr conversion. I've messaged every person wrecking a Scion XD on ebay only to be told they don't keep them. Does anyone have an available source for these? I've also tried to purchase them new, but only one is showing as potentially being in stock - the RH one. |
#380 | |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
#381 |
Yeah the mounts or isolators should be pretty easy to get a hold of, even in Aus. The parts I'm struggling to find though are the ones outlined in red. Based on the reading I've done, I need all 3 of these as well don't I?
#382 |
Technically you can get away with only using the right hand side mount and isolator.
Do you have a lb or sedan?
#383 |
It would be a hatch.
Or am I confused... If I buy the XD dogbone and the XD gearbox isolators, will they bolt to the Yaris equivalent of the parts I've outlined in red? Last edited by stidnam; 12-20-2017 at 03:41 PM. |
#384 |
Yes technically they will bolt up albeit with some force of a pry bar and an extra hour and cursing to get the bolt through.
Based on my extensive experience of using all of the different types of mounts (xd and yaris) mate the proper bracket with its proper isolator to ensure ease of install. The only difference is the xd mounts/isolators will place the engine a bit lower, slightly further away from the firewall and the way Toyota engineered it to sit. However using yaris mounts/isolators will also work as that is Tom's current set up I believe. Either way you will need the right hand side mount and isolator from an xd as the yaris one will not work with the 2zr. The other two that both bolt to the trans case are fine to run either xd or yaris. If you run all xd mounts then it's recommended to run xd shift cables as the yaris ones are shorter and you risk snapping them
#385 |
thanks tmontague. Appreciate the advice.
I'll keep hunting for a full set of brackets. Sounds like that's the cleanest solution. |
#386 |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
Cannot wait to do this to mine. hopefully it works.
#387 |
If the Yaris harness is removed and an xD harness put in its place, where do the 3 speed sensor wires that go into positions 11, 12 and 13 in the xD CA2 come from? Is there another harness that contains the speed sensor wires to be transfered over?
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 09-18-2018 at 09:48 PM. |
#388 |
Data doesn't lie
#3
#389 |
![]() Drives: scion xa 2006 manual Join Date: Mar 2017
planning on a 2zz swap into an 06 xa... i plan on using this thread for general guidelines as the comprehensive gist is pretty similar. gotta say that this is by far the most active and extensive thread for yaris swaps that i can find, and it really seems like OP knows what he's doing! big thanks to AR and everyone who contributes for the help!
feel free to shoot me a different direction if you see fit!
#390 |
Data doesn't lie
A 2zz swap will be awesome, make sure to create your own thread to share the journey
#391 |
^ I will be watching this, big time!
#392 | |
#393 | |
my hopes are that the sizes of the 2zz vs the 2zr with a c60 are identical and that the engine bay dimensions in that of the yaris are also the same as the xa bay. along with distance between the hubs. i will have to find out if the axels from a celica will fit as well. IF the dimensions mentioned above are all luckily the same, my next question is, how did the xd axels fit from the c60 trans to the yaris hubs? new distance (2zr w/c60 in yaris)was spec for the xd axels?? and then i gotta see if it works in my engine bay with celica axels and a 2zz.....
#394 |
The xA chassis is the same as the Echo. They have a smaller engine bay. You’ll have to cut both frame rails to fit it in. The 2zz is about an inch longer than the 1NZ and the pulleys will run right through the frame.
I’m not 100% on the axles swap because I used a C160 witch retains the stock axles. |
#395 |
Data doesn't lie
The xD axles worked perfectly for me since the 2zr and C-transmission were originally designed to be used in this arrangement.
I dont know if the 2zz is longer than the 2zr, but the Celica differential uses the same axle spline as the xD |
#396 |
The motor mounts place the transmission so you could probably use xD axles then with the C60
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
