Old 03-07-2017, 02:32 PM   #91
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
Am getting confused single step double step can u explain ??
so they way off r.l bi 6" l.l bi 3 " am goin to check tonight
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 03-07-2017, 02:39 PM   #92
Sorry. Okay, you know how projectors have a cutoff? The cutoff is comprised of a lower line, slant in the middle, and continues as a higher line, so a single step. When the passenger side's lower line is at the same level as the driver side's higher line, the entire cutoff is comprised of two steps.
Old 03-07-2017, 02:44 PM   #93
Yaris874
Yaris874's Avatar
so this is single step
Old 03-07-2017, 02:46 PM   #94
Single step set up:
Double step set up:
Old 03-07-2017, 02:49 PM   #95
That would be a double step.
It's all just preference, but I ended up going to the single step (proper way actually) from a double step. In order for me to not blind on coming traffic at the time, I had to get the passenger side along a parallel wall to be as close to horizontal as possible, and then adjust the driver side down. Well, that sacrificed some throw in favor of shining up road signs, and that just wasn't worth it to me.
Old 03-07-2017, 02:52 PM   #96
Yaris874
Yaris874's Avatar
Thank u bro I learn something new today thank u
Old 03-07-2017, 02:55 PM   #97
No problem. Drive around which each set up to see which you like better.
Old 03-07-2017, 02:57 PM   #98
Yaris874
Yaris874's Avatar
Maybe u can help me with this so I put the hid h3 in but because was h4 so I connected the Lil motor for the cutoff for high beam I connected to ground of the h4 plug and positive on the highbeam plug so when I flick to high beam the hid cut off so I purchased this maybe Thas the issue?? What u think
Old 03-07-2017, 03:20 PM   #99
Try unpinning the two vertical prongs on the harness (the part that plugs into the OEM connector) and switch the two and repin. Try that to see if it fixes your high beam issue.
Old 03-07-2017, 03:23 PM   #100
Yaris874
Yaris874's Avatar
Ok thanks
Old 03-07-2017, 07:49 PM   #101
ryryAP2
Drives: 05' Honda S2k, 15' Toyo Yaris
@yaris847 was thinking of doing the same setup without the relay. Amazon had similar products, but of course I needed to get ballasts and bulbs. I went with Kensington ballasts and bulbs and iJDMTOy easy relay harness for the bi-xenon.
ryryAP2 is offline   Reply With Quote
Old 03-08-2017, 07:54 AM   #102
Yaris874
Yaris874's Avatar
Old 03-08-2017, 08:19 AM   #103
Yaris874
Yaris874's Avatar
Nice take some pictures when u done
Old 03-08-2017, 02:29 PM   #104
So you went back with the double step set up?
Also, did switching the prongs help your high beam issues?
Old 03-08-2017, 03:07 PM   #105
Yaris874
Yaris874's Avatar
I switch the prongs around an the other side star working so I think I need that plug with the relay I got it is on the way
Old 03-05-2018, 12:15 AM   #106
David C
Drives: White '07 3dr LB
Update on the mini projector installation ?
David C is offline   Reply With Quote
Old 01-04-2019, 09:02 AM   #107
ojeysky
Drives: Sedan Yaris 2010
Originally Posted by Yaris709 View Post
Just wondering if the newer type led's with the heat sink on back will work in the h4 yaris headlights? Since the h4's have that rubber seal around the back of the bulb. And a good bright reputable led if anyone knows what brand is good!
I recently purchased one of these and I am having a hard time fitting the rubber seals. Any suggestions?
ojeysky is offline   Reply With Quote
Old 01-04-2019, 09:05 AM   #108
IllusionX
Drives: 07 Yaris Sedan Aero
I had to cut the 4 nibbles out. You have to install the holder, out the rubber on and turn to lock the LED in place.
Having a few very very odd issues after LED conversion Astroman In Car Entertainment + Electronics (audio / video / alarm) 8 08-03-2014 06:53 AM
Does anyone realize yarisworld is getting 'less busy'? caineroad General Yaris / Vitz Discussion 84 11-05-2013 01:19 AM
FREE Projector Headlights OR LED Tails in exchange for appearance in how-to video V70R_Blackbrick California 4 10-13-2013 11:57 PM
Yari gets a sway bar and a rim change (again) D&D Photo-Video-Media Gallery 8 09-16-2013 02:10 AM
Cruise Control kicking itself out GTBaker Third Gen Yaris General Discussion 9 09-05-2013 10:39 PM
