Old 02-11-2019, 10:02 AM   #1
mik23
Drives: yaris 2005
Front WIndshield washer pump
Hi All,
I have checked the nozzle pipe its working apparently the front pump is not working.
I have looked at the fuse 20A I think its for both front and rear.
How can I access the pump it seems it is behind the front right tyre.
Can anyone help pls how to easily access the pump for further investigation.
Many thanks
mik23 is offline   Reply With Quote
Old 02-11-2019, 10:55 AM   #2
sceh
Drives: yaris 2004
Quite easy. There are two pumps btw, one for the front and one for the back and both are attached to the water reservoir. Buy new ones on Ebay for around 5 euros each too.
The reservoir is on the right hand side looking from the rear.
Jack up the car and take the front wheel off.
Undo the studs that attach the wheel arch liner. You don't need to remove it all, just undo the ones near the front plus there is one underneath the front valance.
You can then bend the liner sufficiently to get your hand in and access the pumps and the connectors. The liner is flexible and slotted into parts of the wing - bend it because it won't break. Remove pumps and replace.
Simple. I have done it twice and it takes 20 minutes
sceh is offline   Reply With Quote
Old 02-11-2019, 10:56 AM   #3
sceh
Drives: yaris 2004
I do believe Haynes talks about removing the headlight - don't
Old 02-11-2019, 11:23 AM   #4
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
the pump can be removed through the wheel arch. Turn the wheel all the way, or just remove it, bend the liner
I like very much travel
MickZEL is offline   Reply With Quote
Old 02-11-2019, 12:41 PM   #5
mik23
Drives: yaris 2005
Excellent Gents
Just to clarify do i need to remove the wheel or not.
I have looked at the wheel there are m10 plastic fastners and m6 screws at the plastic arch.
Sent from my SM-G930F using Tapatalk
Old 02-11-2019, 12:56 PM   #6
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
It is better to remove the wheel to get to the pump with two hands. It must be disconnected from the wires. It is difficult to do this with one hand.
Old 02-18-2019, 11:52 AM   #7
mik23
Drives: yaris 2005
Thanks Gents
Are there any videos manuals
Old 02-21-2019, 05:00 PM   #8
mik23
Drives: yaris 2005
Gents
Thanks for the responses
I have managed to access the pump from front wheel turn clean the nozzles motor checked.
Its all working like a charm.
Inexpensive fix for low windshield washer fluid light stiuck on Toolaholic DIY / Maintenance / Service 5 04-21-2020 02:46 PM
FS Palmdale,CA: Floor mats, windshield washer, hubcaps, vvti cover, hatch container AGlobalThreat Items for Sale by private party 15 08-19-2013 12:34 PM
2012 Yaris LE Windshield Washer joe_cur General Yaris / Vitz Discussion 6 03-01-2013 01:59 PM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
Tinting front windshield Dylanby Cosmetic Modifications (Exterior/Interior) 34 11-25-2006 03:03 AM
