Old 02-19-2019, 02:12 PM   #1
rLipiner
Drives: 2015 Yaris
Transponder key programing
I am trying to make some extra keys for my 2015 Yaris. I ordered they correct key with the chip, mine was an H chip, and got it cut. I am trying to figure out if there is a way too get into programing mode to accept the new key without haveing to use the toyota tis software. I saw some youtube videos for other toyotas where they put the key in 5 times and open and close the door 6 times but it didnt seem to work for my 2015 yaris. any help would be appreciated
rLipiner is offline   Reply With Quote
Old 02-20-2019, 03:37 PM   #2
B.B._07
Drives: 07 5dr
You need some dedicated hardware to program the key transponder. It pays to shop around to find the best rate for programming your keys. Try the locksmiths, auto parts chains in your area. I hear that even Ace hardware has good rates on programming keys.
The door closing and opening procedure is to the program the keyless entry, it won't do anything for the immobilizer chip in the key.
Old 02-20-2019, 06:26 PM   #3
rLipiner
Drives: 2015 Yaris
I got a quote for $70 just to program from a local locksmith. So I went ahead and ordered the programming software and obd2 cable from amazon for about $35. We’ll see how it goes.
Old 03-01-2019, 01:06 PM   #4
rLipiner
Drives: 2015 Yaris
I was able to program the key using the Toyota tis software and cable from amazon. Thank for your help.
Old 03-12-2019, 07:34 AM   #5
lespaulstd
Drives: Yaris
I did it that way in a euro-spec 2006 yaris following the instructions in this video:
https://www.youtube.com/watch?v=4F3Xu_GdbqU
lespaulstd is offline   Reply With Quote
Old 03-24-2019, 10:22 PM   #6
CrimsonEclipse
Drives: .
Any chance you can post a link to the cable and software?
CrimsonEclipse is offline   Reply With Quote
Old 03-29-2019, 08:22 PM   #7
rLipiner
Drives: 2015 Yaris
Yueku Mini VCI J2534 Toyota TIS Techstream Cable Car OBD2 Diagnostic Cable (1.4.1) https://www.amazon.com/dp/B078VKM1G3..._SARNCbWQM5KXR
Old 03-29-2019, 08:24 PM   #8
rLipiner
Drives: 2015 Yaris
If you have trouble installing the driver for the obd2 cable just contact the customer support and they will open up team viewer and fix it for you that’s what they had to do for me.
Old 04-06-2019, 08:19 PM   #9
CrimsonEclipse
Drives: .
Bought it, needed customer service.
Now it works.
Thanks a million!
Old 07-29-2021, 04:13 AM   #10
JanForsy
JanForsy's Avatar
Drives: My wife
When you buy a house, you want to make sure that there are no kinks in the system before you move in. That means installing a keypad lock on all the doors and windows. Explain how you can tell when a window or door is being locked and explain why having a keypad lock is a good idea. It's essential to have multiple options when it comes to installing a keypad lock. If you choose to install one, it's important to remember that it's not a replacement for a physical security system. The one from https://www.locksmithsingapore.sg/ is the best.
JanForsy is offline   Reply With Quote
keys, transponder
DIY Transponder Key Program? 268i General Yaris / Vitz Discussion 0 06-18-2017 06:59 AM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Lost key (transponder and remote lock/unlock) shyeoh DIY / Maintenance / Service 4 07-11-2013 05:04 AM
Reemplazo Swichera yukardo Central and South America 3 04-03-2011 12:11 AM
Yaris transponder key: do we ALL get one?? auxmike DIY / Maintenance / Service 10 12-01-2008 10:40 PM
