Old 03-20-2019, 04:02 PM   #1
cator
Drives: 2008 Toyota Yaris
Replacing rear shocks
I have a 2008 yaris sedan. I know that the hatchback has the location for screw for the rear shocks in the trunk, but where do I access the top screw on the sedan.
Thanks,
cator is offline   Reply With Quote
Old 03-20-2019, 04:07 PM   #2
esse10
Drives: 2009 yaris 2 door
rear shocks
I replaced mine last year, lift up on a plastic cover in the trunk right above the tire. very easy to replace those shocks.
esse10 is offline   Reply With Quote
Old 03-20-2019, 04:31 PM   #3
Sedan is not nearly as easy as the hatch. I believe you need to remove the entire plastic panel on the left and right sides of the trunk. Don't know why they didn't provision the access panel we have in the hatch.
Sent from my EML-L09 using Tapatalk
Old 03-20-2019, 05:33 PM   #4
tmontague
tmontague's Avatar
The access is actually from the cabin not the trunk. Flip down rear seats and you will see plastic cowlings beside each seat that goes around the wheel arch.
Remove those and the shock mount is behind it. For future you can always cut a hole in the plastic as the seats cover it anyways
Old 03-20-2019, 09:37 PM   #5
tmontague
tmontague's Avatar
Here is a picture of the top of the shock with everything removed
Old 03-21-2019, 12:56 PM   #6
Well that pic might just scare the crap out of the OP. He's new and prob doesn't know why your car looks like that.
Old 03-21-2019, 01:14 PM   #7
tmontague
tmontague's Avatar
Lol, it was meant to show where the location is so that you know what is in the way that you need to remove. Not everything in that image needs to be removed!
Old 03-22-2019, 12:40 PM   #8
cator
Thanks for the information, i will be doing it this weekend!
Old 03-23-2019, 12:35 PM   #9
2bz
Drives: 2008 Yaris 3DR Hatch MT
That's what a yaris looks like when you are hunting all the water leaks!
2bz is offline   Reply With Quote
Stock OEM front struts, aftermarket rear shocks? rexseesyou Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-25-2014 01:16 PM
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 02:49 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 06:02 PM
