Old 07-05-2019, 06:24 PM   #1
DAEL
Drives: 4 DR YARIS SEDAN
AC leak after getting stuck in the mud
I have a 2007 Yaris 4 door got it stuck in the mud a week or so ago and now the AC went out. Well the engine revving in gear shifting to try to get it unstuck may have helped? It served me well for 12 years why now?
DAEL is offline   Reply With Quote
Old 07-06-2019, 02:16 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Why now? It sounds like you may have answered your own question. You rocked the car back and forth, probably damaging an A/C hose or fitting - and hopefully nothing else. Or, it had nothing to do with your treatment of it and it just failed due to age. There is no way to diagnose this without seeing it, so if you want A/C, then take it to a shop, get it properly diagnosed and repaired.
Old 10-01-2019, 12:37 PM   #3
DAEL
well I recharged it and leak sealed it and it's working fine now, had my doubts for a minute!
Old 10-01-2019, 01:12 PM   #4
06YarisRS
Great! 12 years is pretty good service especially if it's not been touched since new. Compared to other cars I've owned, the Toyotas seem to have a pretty durable a/c system.
Old 10-01-2019, 09:19 PM   #5
tmontague
tmontague's Avatar
Agreed
2007, air conditioner
Evap system leak detected. Evap incorrect purge flow. BlackTy DIY / Maintenance / Service 12 06-22-2022 02:35 AM
My Echo Exhaust Leak in Front ? frank2005 General Yaris / Vitz Discussion 8 08-02-2017 09:52 PM
Red Angel Stop Leak - Need Advice Boba Ben DIY / Maintenance / Service 2 07-20-2017 10:36 PM
Yaris Hatch Leak Finally Fixed Yari$ DIY / Maintenance / Service 2 07-09-2017 10:43 PM
