![]() ![]() ![]() Drives: Yaris manufactured after 2007 Join Date: Nov 2010
Homemade tools for coolant change
I followed the instructions for changing coolant given by tmontague (and minitip by johnwk) at this post http://www.yarisworld.com/forums/showthread.php?t=61899 . I will reproduce those instructions in the next post (below).
But I want to share some home made tools that I used to do the job that worked well. First, I made a drain pan out of an apple juice container turned on its side. I cut a rectangular window (hole) in the side of the container to allow the coolant to flow in. See attached picture, you can see the rectangular window cut in the white nutrition information on the side of the container. I made a funnel out of the top of an empty 2 liter soda pop bottle. When you drain the coolant out of the bottom of the radiator, it shoots out the drain which points parallel to the ground and does not go through the hole in the plastic under-engine guard. So I cut a slot in the funnel and put the drain through the slot and put the bottom of the funnel in the hole in the plastic under engine guard. The old coolant hits the side of the funnel, then goes through the funnel and hole in the plastic under-engine guard and then through the window in the home made pan into the pan. I have included a picture that shows the funnel with the slot sticking in the window (hole) of the homemade drain pain. The slot in the funnel has a pen in it which shows how the horizontal drain fits into the slot & funnel and the pen points in the same course & direction that the old coolant follows when it drains from the bottom of the radiator and out the horizontally pointed radiator drain. I made a second funnel out of the top of another empty two liter soda pop bottle. When the drain pan is near full, I slid it out from under the car, being careful to keep it horizontal. I put the second funnel in the top of an old plastic milk container, then I unscrewed the cap on the drain pan (old apple juice container) and transferred the old coolant to the old milk container. I took the old coolant (in the old milk container) to the dealer where I bought the new coolant (antifreeze) for proper disposal. I have attached a picture of the second funnel. I also used the second funnel to put new coolant into the radiator. I have given a little more info in the next post, because this one is pretty long. Thanks, RMcG Last edited by RMcG; 07-25-2019 at 05:59 PM. |
#2 | |
I ended up using the older Toyota Red 00272-1LLAC-01 coolant for the new replacement coolant, which is discussed in the previous thread http://www.yarisworld.com/forums/sho...t=61899&page=2 and I diluted it myself. Much to my surprise, the local Toyota dealer carried this older coolant. Thanks to everybody, especially tmontague, whose instructions are reproduced below. R. Instructions from tmontague: Do it yourself in the parking lot - here's how: Buy a large oil drain pan (or equivalent plastic container) and slide it under the front of the car where the drain petcock in on the bottom drivers side of the rad. Look for a yellow plastic knob, you can reach it from the top of the engine bay. It may be stuck but be careful because you can break it. Drain the coolant out from this pet cock (remove rad cap to speed this up and make sure coolant is not hot!). This will take 20 mins or so to fully drain, but once it stops draining close the pet cock and re fill with fresh Toyota coolant (50/50 mix) from the rad cap. Fill until it over flows. Then squeeze both the upper and low rad hoses a few times and if the coolant level drops at the rad cap, re fill until it is at the top. Keep the rad cap off and start engine. The coolant level will drop, refill it again until it is full and put rad cap back on then turn off engine. Make sure your overflow reservoir is full of coolant to at least the F line if not more. Turn the car on and go for a drive. 20 minutes in current temps should be enough to get coolant up to operating temps, go for a jaunt on the highway and back. Get back home and park the car. Check the coolant level in your overflow reservoir, it likely dropped some. Fill it back up to the F mark. Once your coolant is cool enough, remove the rad cap and if the coolant is not at the top then fill it to the top and replace the cap. Drive the car as your normally would over the next week but after every day check the overflow reservoir and refill it so it is at the "F" mark. After a week of this you no longer need to keep checking it. The yaris burps the air out of its cooling system very well by itself as the fill neck is properly situated as the highest point in the system. As it burps air itself it will pull coolant from the reservoir tank which is why you need to check it after you drain and refill the system. Your only potential issue may be needing to use pliers on the drain petcock valve to crack it open. It is easier to do from under the car but can be done from above. Just be cautious not to crack it. Warmer temps help keep the plastic more pliable. You can easily drain the overflow reservoir by removing the small diameter hose from the radiator fill neck. Once it is removed lower it in the engine bay so that is points into your drain pan. Once it is lower than the outlet on the reservoir, coolant will automatically drain from it. Johnwk's mini-tip: I found that only unscrewing the radiator drain plug part of the way prevented it from spraying all over the plastic under-engine guard (where it will collect and sit). Last edited by RMcG; 07-25-2019 at 06:02 PM. |
#3 | |
I will probably only unscrew the radiator drain plug (at the bottom of the radiator) part of the way in the future (as suggested in Johnwk's minitip), rather than making my fancy homemade funnel with the slot in it for the horizontally shooting stream of draining old coolant at the bottom of the radiator. But this system does work. And the homemade drain pan and homemade regular funnel (without a slot) do work; and the old mushroom trays work too and they will work for everybody no matter what system you use. Thanks, R. Last edited by RMcG; 07-25-2019 at 02:22 AM. |
#4 | |
It is also easy to make one of these funnels with a slot cut in it. You can get such empty soda pop bottles from a recycling bin if you don't have any of your own. I think a bottle smaller than 2 liters would work for a funnel with a slot as well. I am now almost finished with my own coolant change; I just have to add small amounts of more coolant to the system over the next week or so as the level goes down slightly with driving. Thanks everybody, especially tmontague. ![]() R. |
#5 | |
R. |
Loosen the rad cap and pull the lower rad hose. Also, I find it easier and cleaner to pull the lower plastic shroud off. That way the coolant doesn't run and drain from everywhere.
| Tags |
| change, coolant, homemade, tools |
| Custom Instrument Cluster LED Color Change Service | CTScott | Items for Sale by private party | 74 | 06-10-2022 01:29 AM |
| Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 06:40 AM |
| Tools to change front and rear suspension | yariseggvvti | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 01-07-2013 01:09 AM |
| AC doesn't work on startup until I change circulation | Applejam | DIY / Maintenance / Service | 1 | 09-29-2012 09:28 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
