Old 08-04-2019, 12:22 PM   #1
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
Changing out a plug in 2007 Yaris sedan
Getting misfires on cylinder 1( started a thread on that). Wanted to look at plug . Here’s some pics and tips.
Toolaholic is offline   Reply With Quote
Old 08-04-2019, 12:32 PM   #2
Toolaholic
Thexton 492 spark plug starter . Old plug boot or rubber hose works too. If plug is cross threaded hose will slip
File Type: jpeg 47333BDB-885C-4545-84DD-A36166819A42.jpeg (166.9 KB, 29 views)
Old 08-04-2019, 12:35 PM   #3
Toolaholic
Plug threaded in
File Type: jpeg E46A657A-B05E-4E07-A9F5-F1C89CBDE98F.jpeg (320.5 KB, 29 views)
Old 08-04-2019, 12:38 PM   #4
Toolaholic
I then bottom it with extension /spark plug socket. I have a 1/4 adapter for 1/4 torque wrench. I spin up and down to make sure plug moves freely and no cross thread. It will feel gritty because of carbon deposits on threads in spark plug hole.
File Type: jpeg 851E8059-8D11-4966-8146-50D864167E10.jpeg (333.6 KB, 29 views)
Old 08-04-2019, 12:53 PM   #5
Toolaholic
Torque spec is 13 lb ft or 156 inch lbs. I set wrench to 170. I’d rather err slightly tighter than looser. 1/2 turn seated plug gaskets. I actually loosened again and spun plug up and down to again checking for cross thread.. Torqued again this time 1/4 turn til click because gasket on plug was crushed. If the plugs been in a awhile sometimes a 1/8 turn will click.
File Type: jpeg 13CE402C-B52B-449D-9D25-6207CEB6EBC3.jpeg (416.1 KB, 27 views)
Old 08-04-2019, 12:57 PM   #6
Toolaholic
Super lube dielectric grease in coil . A dab put in top of boot.
File Type: jpeg 07653D83-06D3-447A-BD27-05413775DABE.jpeg (146.7 KB, 29 views)
Old 08-04-2019, 01:01 PM   #7
Toolaholic
Torquing coil 10mm bolt to 80 inch lbs.
File Type: jpeg 2EA17D83-BB21-4C38-9565-4C1FC57BED89.jpeg (215.9 KB, 29 views)
Old 08-04-2019, 01:04 PM   #8
Toolaholic
Torquing cover 10mm bolts to 80 inch lbs
File Type: jpeg C0A0AA7D-B252-4DC0-A5A9-33F77BC971DE.jpeg (244.0 KB, 29 views)
Old 08-04-2019, 01:20 PM   #9
Toolaholic
And if you loose the insert washer on top of cover a 7/8 washer fits
2007 yaris sedan aux jack... chief ten bears In Car Entertainment + Electronics (audio / video / alarm) 13 10-26-2016 11:38 AM
Tein Street Basis Coilover Install - 2007 Yaris Sedan NCP93 Stock sheekeebut Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-13-2014 01:32 AM
2007 Yaris Sedan Front Grille Stacieee Cosmetic Modifications (Exterior/Interior) 1 05-29-2012 10:48 PM
