Old 08-27-2019, 11:16 AM   #109
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Originally Posted by ezhacker1 View Post
I too went from diode between the hi and low to Morimoto MotoControl. Best thing ever. But i do hate these housings for retrofitting (Morimoto Mini D2s 5.0) ....
I have had Morimoto Mini H1's and D2S' on Rav4 and Corona and they were fantastic. On the Yaris I'm holding out since I have a working JDM setup. I think the D2S 5.0 will be the next upgrade. For now I'm looking to get a Morimoto harness to drive the JDM units for another few months before I decide to upgrade.
What's the issue with the housings? I'd think it would be easy since they are big. My Rav4 had really small headlights and it was a pain trying to get the projectors in right.
Regards,
DeeBee
DeeBee is offline   Reply With Quote
Old 08-27-2019, 08:44 PM   #110
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
You still have to cut around the OEM bulb opening to fit the thread of the projector. Also threaded on without modification means the beam is too low. You run out of vertical adjustment. Could well possibly be I'm using aftermarkets housings as I dont have 08 style OEM, my car is 09. But the aftermarket allows me to have horizontal adjustment.
Mini D2S 5.0 is much better than the 4.0 IMO. the step isnt as big. I hated the dead zone of light on the lower step. Highbeams always looked good for these projector price range.
Check out my Build thread:
Old 08-28-2019, 01:45 PM   #111
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Thanks for the info. I'll certainly take a good look at vertical adjustment when I make that move.
Regards,
DeeBee
Old 12-29-2019, 08:13 AM   #112
fredovvti
Drives: Yaris 07 HB
I change mines to LED and the different is BIG!! Try it!!
fredovvti is offline   Reply With Quote
Old 06-01-2020, 05:11 PM   #113
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
OK I was wrong last year about the Negative Switched, and before I go back out and start hacking on my cars (ok being too lazy, and at work, to go back out with my meter) I wonder if any of you experts know... IS The Positive Terminal on the H4 Halogen lights (Right at the bulb) "Hot" ALL the time?
OR Hot ONLY when The Headlights are turned ON?
Your Input is Appreciated!
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Old 11-15-2020, 03:44 PM   #114
govtec
Hi guys, so after 3 years my low beams suddenly stopped working the other day. High beams and everything else works. I’ve checked the engine bay 10 amp fuse and they are fine. Any idea where I should look next? Thanks
govtec is offline   Reply With Quote
Old 11-15-2020, 06:17 PM   #115
enviri
enviri's Avatar
Drives: 2010 Yaris
ballast and bulb. its 90% most likely the bulb. both went out at the same time eh?
Old 11-15-2020, 10:39 PM   #116
govtec
Yes, at first I doubted both bulbs would go at the same time so I just ordered 2 D2R Osram bulbs from Amazon. I also tried switching out the headlight switch with a new one from Toyota and that didn't work. We'll see if the bulb solves it. Thanks
Old 11-22-2020, 07:34 PM   #117
enviri
enviri's Avatar
Drives: 2010 Yaris
wait you're using d2r with toyota ballasts? that might not be good...should be using d4rs... D2Rs use a good deal amount more energy to light up. It just might be your ballasts too!
Old 12-20-2020, 03:34 PM   #118
govtec
I ended up taking the vehicle to a local mechanic shop and they determined it was a bad relay. They changed it and put a new one in and it's working fine now. Where is the location of the low beam relay?
I used d2r because that is what the HID housing said to use. I also have a relay harness setup...https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 12-29-2020, 11:49 PM   #119
govtec
Quick question...Has anybody tried substituting the H4 male plug with a 9006 male plug to the 4 prong connector?...I'm finding that the cheap H4 relay harness is about to die on me and keeps flickering when I hit a bump on the road after about 3 years of use and I can't seem to find a quality H4 relay harness in the market. Morimoto makes a 9006 relay harness but will require a 9006 plug, so that is why I am asking this question. Thanks
File Type: jpg Screen Shot 2020-12-27 at 9.49.11 PM.jpg (83.5 KB, 45 views)
FS: 2012 Yaris oem headlight projector retrofit ucsmfu Items for Sale by private party 4 11-01-2016 11:28 PM
How can i get the OEM Headlight Stalk with FOG switch to work murtaza.shahid DIY / Maintenance / Service 0 11-22-2014 07:30 AM
FS: Seibon, HID, JDM RS Tails, Shift Knob, Oddysey PC680 Battery, etc.. -- Socal 03Z33 Items for Sale by private party 30 01-02-2009 07:55 PM
DIY - JDM RS style REPLICA tails kurokoma-kun DIY / Maintenance / Service 0 10-21-2008 03:56 PM
