![]() Drives: 2008 Toyota Yaris Join Date: Feb 2019
Leaking From Above A Pillar
Anyone had any problem with leaks above the A pillar? I think it's from underneath where the "drip moulding" is supposed to clip to. That wasn't my first guess, I put silicone windshield repair between the windshield and the car but that didn't stop the leak. I removed the roof liner to get a better look at it. I plan to just pour silicone on everything that I can to get it to stop. It drips on my leg and it is pretty annoying. Any ideas?
In the pics there is some water still there from testing it. |
![]() Drives: '10 Hatchback Join Date: Dec 2016
See the crack in the paint just behind the clip? That crack likely goes through the sealer that covers the welded joint at the roof edges.
Get a tube of body sealer from an auto parts store, and brush it all over the bottom of the trench. Silicone dries and cracks over time...found that out the hard way. I can't tell from your 3rd photo - does that large circular hole allow you to get at the clip's bolt/nut from the underside? If you can, remove that clip, and seal under it too. If not, reach through and brush sealer from underneath. |
Running w/o gutter strips. Noticed and probed-to-confirm-clear what I interpreted to be a deliberate drain hole into the top of the A-pillar. Hole is near the corner of the glass.
![]() ![]() Drives: 2007 Toyota Yaris 3dr Join Date: Aug 2017
I have the same exact issue. I will pull out the molding an apply the black body sealer as well.
The Gibbs Garage 2016 Lexus GS350 f-sport (my main car) 2013 Lexus RX350 (wife's vehicle) 2010 Toyota Tacoma (my second vehicle) |
#5 | |
![]() Drives: 2007 Yaris Coupe Join Date: Aug 2016
Kind of obvious problem at 70 MPH and something slapping the back of the car. I ripped them off and now I've got tiny leak at A Pillar just above me, The Driver. I'm going to look into this Body Filler Stuff. I was just going to silicone over the holes that cannot be seen until I get it properly fixed. I guess "Body Filler" IS Bondo? That would not be the thing to do if one ever wanted to fix it Right. Body Man.....OK. DIY...No. I guess what is Right to some is different for others. Last edited by ct77414; 05-27-2019 at 08:48 AM. |
#6 | |
I wanted to test covering potential points where the water is leaking in with the silicone I had before I went ahead and got seam sealer, removed the silicone, and really covered things in a durable way. I covered everything up that looked like a crack in the gutter and the leak didn't go away. That's when I started looking for other places the water could be coming in. Eventually I put silicone across almost the entire width of the car where the windshield meets the roof. This finally killed the leak...so far. A picture of my terrible handiwork is attached. |
Just want to update this in case this happens to someone else.
Putting silicone between the windshield and the car didn't actually solve the problem, and was probably completely unnecessary. I had a small crack in the gutter farther up than I thought was possible. Basically at like the highest point of gutter. I sealed it all up with silicone (which Mike Dexter mentioned will fail eventually, I'll get there when I get there) and it finally went away. |
#8 | |
![]() Drives: 2008 Liftback/Black/5-speed MT Join Date: Sep 2009
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Interesting, i had water leaking into the boot of my car. It was very difficult to get the bottom of where exactly it was coming in and in the end i got very pissed off and plastered everything in urethane seem sealer - including the back end of the gutter and all around where that hook was at the back. There did indeed appear to be cracks in the paint around this area. It fixed my leak, at least for now.
Water leaks really are a pain.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
#10 | |
![]() Drives: 2008 Yaris 3dr Join Date: Aug 2020
the correct fix for this is to remove some of the OE seam sealer (wherever and everywhere its cracked)with either a knife or a cutoff wheel to widen the crack, at which point you get some 3M "seam sealer" and re-apply as the factory did..this will perminantly fix the problem for another 20 years
![]() Drives: Yaris 2nd Generation Join Date: Aug 2023
Strange how this leak problem happens when the car is 12 years old!
I have just started to get a fungus smell in my 12 year old Yaris, and all the footwells and boot are dry. I will take the roof lining off and have a look when I get time. Toyota should do a recall for this fault. |
![]() Drives: 2006 Yaris 2dr hb manual Join Date: Oct 2021
Having the same issue after washing the car or rain. Glad to hear it's an easy fix, going to take care of it rn.
#14 | |
I have included photos of what appear to be depressed areas on the surface of the driver's side molding gutter. Could either of these be the cause for the leakage inside above the driver's seat?
#16 | |
Drives: Yaris 2008 Hatchback Join Date: Jun 2025
thanks in advance |
![]() Drives: yaris Join Date: Oct 2010
I want to post question regarding changing transmission fluid for yaris 2016 , how I post the question?
| Leaking rear wheel cylinders? | xdarkxfirex | DIY / Maintenance / Service | 8 | 04-11-2017 02:47 PM |
| Chrome pillar trim for 3 dr | Foot | Cosmetic Modifications (Exterior/Interior) | 3 | 01-26-2013 04:09 PM |
| Water Leaking into car! | CKaelin | General Yaris / Vitz Discussion | 18 | 08-16-2012 01:53 AM |
| Axle seals leaking caused by lowering ride height? | NH3R717 | DIY / Maintenance / Service | 2 | 07-22-2010 03:29 PM |
| Fishing an AV wire down B pillar | redyaris | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-10-2007 06:17 PM |
