#433 |
![]() ![]() Drives: 07 Yaris 4DR Join Date: Jun 2009
My ABS and ! light came on this week. I took it to the dealership to diagnose and they came up with rear left, and front right. I said hold off on the repair (and they wouldn't inspect my rear right for some reason). Picked the car up, and the light has been off. Took it to another mechanic I trust, and he said to drive it as-is until the lights comes on again.
#434 |
My ABS and ! light have been coming on more often. I took it to a small mechanic I trust to diagnose.
ALL my sensors showed up on the history, which led my mechanic to think it wasn't a sensor problem. The mechanic cleared the codes, and went for a drive. My right rear sensor came on immediately. I'm going to drive it for a week or so, and go back to see if the other sensors will come up again. |
#435 |
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
Cars don't fix them selves.
#436 |
Took the Yaris back to my mechanic. The rear right, and ONLY the rear right, ABS sensor came up on the scan. I'm going to replace the rear right and the harness next Saturday. Hopefully that'll be the end of things.
#437 |
![]() Drives: 2008 Toyota Yaris Hatchback Join Date: Apr 2016
Is there a video tutorial on how to do the cleaning and grease trick using WD40 and dielectric grease for the sensors? Or can anyone make one? I'm not very handy or knowledgeable when it comes to cars. But this trick seems to be working for a lot of people having the same problem I am. I've already brought my car to the mechanic twice, first time he replaced the sensor, second time he replaced the bearing. Still no luck, can't afford to keep replacing things if its not going to solve the actual problem! Any help would be greatly appreciated!
#438 |
Is there a reason the mechanic only replaced one sensor? Any of the 4 sensors could cause the issue so replacing one is good, but not if the other 3 are also causing the issue
#439 |
He showed me the old sensor he replaced and I could see it did have some noticeable corrosion. He didn't mention any of the other ones having problems with them. I guess ill have to bring in my car again and have him try to do this clean and grease trick to see if that fixs the problem. Otherwise Ill have to replace more sensors.
#440 |
![]() ![]() Drives: '15 Dodge Challenger Join Date: Aug 2011
had mine go 4 or so years ago, was told it was $700+ to repair so i pulled off the gauge cluster and covered the lights with electrical tape behind the face. Last year when i replaced my front bearings i noticed a ton of corrosion on the speed sensors.
Really a problem that should have been addressed by Toyota. :( Edit: never really needed the ABS, just buying some good tires and brakes and my little Yarii can plow through winter like no tomorrow |
#441 |
My ABS and ! light turned off this week with the warmer weather.
Despite that, I went through with replacing my rear right wheel bearing and ABS sensor harness. Cost me about $450. Fingers crossed the issue doesn't return next winter. |
#442 |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
My ABS light came on yesterday for about 10 minutes, then it turned off. Glad to see I'm not the only one with this issue.
Subcompact Culture: The Small car blog |
#443 |
![]() Drives: Toyota Yaris 2007 Join Date: Dec 2016
My 07 Yaris Sedan base model experienced ABS light on in February 2014. It was a particularly cold winter. It was out of warranty, and the repair at Canadian Tire cost $1177 CAD. Both rear sensors and their harnesses were replaced. Haven't had problem since.
#444 |
![]() Drives: 2005 Yaris Join Date: Aug 2017
is there anyone with used connectors and hub/bearing assemblies? whats the cheapest prices anyone can find these parts for?
#445 |
![]() Drives: 2007 Yaris Join Date: May 2017
I know this is an old thread but wanted to share appreciation for the advice. Had ABS and brake light on this week. 2007 sedan, in Calgary; particularly slushy recently and brakes were still working but no ABS, so this thread sounded like it could be related to the problem.
Per advice I took rear wheels off and checked sensors, sure enough they were absolutely covered in salt. Cleaned and applied some dielectric grease. Now lights are off, tested brakes on a patch of ice and ABS working fine. Fingers crossed that this is a lasting fix. |
#446 |
![]() Drives: Yaris 2007 3 doors Join Date: Jul 2009
went in today , the little outer shell is easier to remove than trying to
remove everything at once with just jamming a mini screwdriver under the connector once the outer housing is removed , it is still touchy to get the connector to come out of the sensor , both sides looked good and the dielectric grease did not change anything for me , both abs and " ! " lights are on , time will tell if they continue to go ON and OFF 50 times an hour when driving , I've been looking at those warning lights for over 5 years , don't care , only thing is once a month the brake pedal goes to the carpet with no stopping and the grinding feeling typical to ABS brakes . Back to the drawing board ..... |
#447 |
![]() Drives: yaris 07 hatchi Join Date: Nov 2020
anyone in sauga/toronto have an 06-08 yaris with cruise. looking for someone to help me install it
#448 |
![]() ![]() Drives: 07 Yaris 3DR Join Date: Apr 2007
Does ANYONE know how to COMPLETELY DISABLE the ABS system and clear the codes? I'm talking so the main ECU doesn't even know the car has ABS, so the fault codes don't come up??
I really don't want to fix this expensive problem and already know it is the rear right sensor causing a problem, but my vehicle won't pass inspection with it throwing codes. I already took apart the connector and cleaned it but it didn't fix the problem. I removed the two ABS / traction fuses from under the hood and tried clearing the codes with a scanner but it doesn't work. It still knows there's an ABS module somehow. I WANT THE CAR TO THINK IT DOESN'T EVEN HAVE ABS AT ALL SO I CAN PASS INSPECTION. Thanks |
#449 |
![]() Drives: Yaris Join Date: Nov 2021
I'm joining the club. Paid $1000 for a 2007 Yaris with 300,000. I'm at 315,000 now and the infamous ABS and brake lights have come on. After reading this thread, it looks like I don't have to worry much. Bring on Toronto winter lol
#450 |
I think you made a wise purchase! I hope you have a good luck with the car.
The ABS module went out on the Ford F150 I was considering buying a used car lot. I told the guy fix the ABS module And I’ll buy it. He fixed it and it cost $700. So I bought the truck. In New Jersey vehicle without working ABS will not pass inspection. Of course it’s not necessary. And statistically it doesn’t prevent accidents or injuries or deaths to any measurable degree. What error codes do you have? Perhaps we can figure out what is wrong with it. It might be an easy fix If you can do the work yourself
