![]() ![]() Drives: 09 Yaris Hatchback Join Date: Oct 2014
2nd gear grinding
So my 2nd gear has started grinding whenever I downshift from 3rd to 2nd over 30mph. If I wait until the car gets to 20mph I can downshift from 3rd to 2nd without any grinding. I changed my tranny fluid about 10k ago and I started using Red Line MT90, soon after changing it to Red line is when I started noticing but it has gotten worse. Since I don't want to force it into second gear I have gotten used to downshift only when it reaches 20mph.
Will I have to replace the 2nd gear synchros? or can a better quality transmission oil help it out? On my turbo honda civic third gear was grinding at some point and I started using GM Synchromesh oil and that stopped the grinding. So I am wondering if I can do the same for the yaris... Any suggestions will be greatly appreciated. |
I had an issue with downshifting to 4th. It wasn't until I changed to Royal Purple 75-90 GL4 that it fixed the problem. That was over 2 years ago now.
Drives: 2008 Yaris Liftback, 5-speed Join Date: Oct 2019
Did The Royal Purple Help?
I have the same issue. The car has 138,000 miles though.
I can avoid grinding, but my wife cannot and I want to avoid gearbox issues. If changing the gearbox oil helps, I'm in! |
I tried a few oils, all of them met Toyota requirements.
But the original Toyota is by far the best. I was very pesimistic about it (I always am when the discussion about any oil pops up) but this original Toyota stuff is really the best. |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
I've heard these gearboxes prefer GL4 dino oil rather than some of these fancy all singing all dancing synthetic oils. I think the Toyota recommended oil for these gearboxes is a single weight not a multi weight. I use this cheap 75W90 semi synthetic GL4 stuff made by Comma and my gearbox seems to be behaving itself.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
![]() Drives: 2015 SE HB Join Date: Jun 2007
Royal purple here too. I put 380,000 km on my 2007, original clutch and transmission. Worst to happen was that downshift to first would grind if I didn't slow down to less than 10km/h.
Sent from my SM-G950W using Tapatalk |
| 2nd, 4th & Reverse Gear Not Engaging | mesci | DIY / Maintenance / Service | 3 | 03-17-2023 07:03 AM |
| Stuck in 2nd gear! | Surubi | Suggestions - Feedback - Questions | 3 | 03-01-2015 03:17 PM |
| 2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) | nookandcrannycar | General Yaris / Vitz Discussion | 7 | 02-22-2014 08:16 PM |
| 2nd Gear lock out | heeroyuy01195 | DIY / Maintenance / Service | 4 | 12-29-2011 01:44 PM |
| 2nd to 3rd gear shift (manual tranny) | tekmoe | General Yaris / Vitz Discussion | 13 | 12-11-2006 06:27 PM |
