Old 06-25-2017, 01:29 PM   #1
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
Inexpensive fix for low windshield washer fluid light stiuck on
Hi all, I use rain x( the orange kind) windshield washer fluid. My low fluid light has been on for weeks regardless of amount of fluid in reservoir. This happened begire and cleared up in a week. This time it was in for like 8 weeks. Not willing to dismantle the front end of the car to replace sensor, I ran reservoir almost dry and filled with distilled water in hopes the pure water would absorb any stickiness, grime that was making sensor stick. It took 2 weeks but windshield washer fluid light went out. Cheap fix that's worth a shot.
Toolaholic is offline   Reply With Quote
Old 06-26-2017, 01:31 AM   #2
xdarkxfirex
Drives: 2015 yaris le
I'd probably run it till its gone and then use a garden hose to fill it up and try to loosen anything that might be stuck. If not. test the sensor and replace. The washer fluid sensor isnt difficult to replace as well if thats your last option.
You can try calling your local dealer. This is the cheapest place I found for this toyota part online. Just make sure it fits your model yaris. https://partsouq.com/en/search/all?q=+8539730400
xdarkxfirex is offline   Reply With Quote
Old 06-26-2017, 01:36 AM   #3
xdarkxfirex
That part number if for yaris's 2012 and up. This one is for the older ones from 07 8539733230
https://partsouq.com/en/search/all?q=8539733230
Old 06-26-2017, 07:50 AM   #4
Toolaholic
Thanks for the links! I thought the front fascia had to come off car to replace it.
Old 04-20-2020, 10:16 PM   #5
SoCalSTEVE
Drives: 2012 Yaris SE
I noticed my dash light doesn’t come on now when my washer fluid is low. Every other lights comes on when started (Could be a bad dash light), I’m guessing a bad fluid sensor on my 2012 Yaris SE with 266,000 miles.
Anyone else have this issue, before I buy a new sensor?
SoCalSTEVE is offline   Reply With Quote
Old 04-21-2020, 02:46 PM   #6
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
My low washer fluid light does not come on when I start the car either. I don't recall it ever doing so. I believe this is normal. Not all the dash lights illuminate at start up.
It does light up when washer fluid is actually low.
DIY- rattle from lower windshield fix. PetersRedYaris DIY / Maintenance / Service 3 08-21-2011 12:29 AM
Adjusting Windshield Washer Jets N9QGS DIY / Maintenance / Service 7 06-08-2010 10:10 PM
Windshield Washer indicater always on mlaverdiere General Yaris / Vitz Discussion 3 01-17-2010 02:43 PM
Windshield Washer Indicator captainm27 General Yaris / Vitz Discussion 25 01-21-2009 07:26 PM
New TSB Bulletin For Windshield Washer Sprayer Yaris General Yaris / Vitz Discussion 14 06-01-2007 01:47 PM
