Old 08-27-2020, 08:07 AM   #1
meemadd
Drives: 2009 yaris
auto trans rpm lowering for mpg
what options do auto trans owners have to lower final drive rpm to increase mpg in second gen yaris?
meemadd is offline   Reply With Quote
Old 08-27-2020, 08:53 AM   #2
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
Are there any except for driving slower or having different gearing?
I'm a hermit named Lee
Leegamer is offline   Reply With Quote
Old 08-27-2020, 09:09 AM   #3
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Like Leegamer says, "drive slower". You could drop the rpm marginally by installing larger tires, but then you'd be using more power to turn them, negating any fuel economy gains. Do you not already get excellent fuel economy? I have the auto in one of my Yari and fuel economy is exceptional. I haven't actually compared the rpm at say 110 kmh between my auto and manual. I should do that.
Old 06-07-2023, 03:14 AM   #4
IndestructibleYaris
larger tires. Trailer tires are taller, 195/65r15s are taller.
IndestructibleYaris is offline   Reply With Quote
Old 01-09-2024, 09:07 AM   #5
JefFrosync
Drives: Man
Send a message via AIM to JefFrosync Send a message via Yahoo to JefFrosync
Have you considered alternative approaches, like adjusting your driving habits, or are you specifically looking for modifications to the car itself to improve fuel efficiency?
For those who have made modifications, how significant were the changes in fuel efficiency, and would you recommend them to other auto trans owners seeking better MPG?
JefFrosync is offline   Reply With Quote
Old 02-08-2024, 03:03 AM   #6
Maeser
Drives: Man
Send a message via AIM to Maeser Send a message via Yahoo to Maeser
Have you explored other options, such as adjusting your driving habits, or are you primarily interested in car modifications to enhance fuel efficiency? If modifications were made by others, how impactful were the changes in fuel efficiency, and would you suggest them to fellow auto transmission owners aiming for better MPG?
Maeser is offline   Reply With Quote
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 04:29 AM
Reluctant upshift to 3rd while cold (auto trans) pauljk General Yaris / Vitz Discussion 40 01-22-2011 07:04 AM
Effects of too much trans fluid in the case? (auto trans) detroiter General Yaris / Vitz Discussion 5 02-25-2009 12:08 AM
What RPM's are you americans getting on Auto trans? BMGYaris General Yaris / Vitz Discussion 12 11-02-2006 03:43 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 11:57 PM
