Old 10-05-2009, 11:19 PM   #1
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
Shorter Serpentine Belt?
I may potentially need a shorter belt due to a smaller alternator pulley.
I believe the stock pulley is 3 inches and the one Ill be using would be 1 5/8 inches coupled with the %10 under drive pulley that make for an almost 2" loss.
Does anyone know How I would go about making up for this loss?
PG TLD22 8V Line Driver
Old 10-06-2009, 01:07 AM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
if your using the NST underdrive kit with the 3 pulleys then you dont need a new belt. the stock one will work fine.
Old 10-06-2009, 01:15 AM   #3
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
A NAPA store should be able to look-up a compatible belt in any length you need, if its made. Others could too, but NAPA stores seem to have more knowledgeable/willing staff.
Old 10-06-2009, 01:16 PM   #4
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Go out and buy like the next 3 smaller sized belts belt and test fit. That is what I had to do on a s/c install I did recently and then returned the ones I didn't need.
Old 10-06-2009, 02:01 PM   #5
i had to buy a smaller belt when i put the nst underdrive on....but i don't have a/c
went 36" to 35.5"
Old 10-06-2009, 08:27 PM   #6
The Architect
Give Me Resonance
thanks guys. dom at irragi alts has the half inch shorter version which should be just fine with the smaller diameter alt pulley (1 5/8)
i forgot how easy it is to move the alt forward and backwards to adjust.
Old 04-20-2021, 11:42 AM   #7
ii had to buy a smaller belt when i put the nst underdrive on....but i don't have a/c
went 36" to 35.5"
grave digging for the #QCyaris!
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 10:58 AM
Pinging belt when wet or cold steveh74 Europe (continental) 0 08-22-2009 06:50 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 10:05 AM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-13-2009 12:05 AM
Best Grease to use on the belt? hasher22 DIY / Maintenance / Service 11 04-23-2007 03:20 AM
