![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Removing B Pillar Covers (2 DR Hatchback 2007)
Update to my post...
https://yarisworld.com/forums/showthread.php?p=828940 -------------------------------------------------------------------------------- I just need a few pointers/tricks to remove properly. I have come across 1 thread on removal but way too vague. I suppose I could just pull off and if I damage /break clips then just double tape back on aswell? I have a feeling this is rarely removed and not many have done so. I found out technical term for the piece btw... https://parts.gatewaytoyota.ca/oem-p...bC1sNC1nYXM%3D Last edited by Pinchlite; 04-26-2021 at 01:29 PM. |
![]() Drives: 2009 Yaris S Join Date: Mar 2019
Just run a plastic tirm removal tool down both sides don't stress the plastic, and then work the clips from the top down because it has a tab at the bottom that slides down into the door.
I ended up putting a crack in it.
Hardly noticable. The old tape really holds rock solid. Getting a new one is really quite expensive for what it is. Getting one from a scrapper is near impossible as you will never see a yaris in a scrap yard.It will be sold as quick as it arrives. |
I didn't have much issue removing mine but it's very hot here so the adhesive is always on the softer side. Just painted them the other day they look better than new, just need to get the car painted so I can put them back on.
I had paint done on my car aswell.Thats why I wanted to get off.
I ended up cracking one.Just going to leave it as they are over $70 CAD for 1 piece. That double sided tape is crazy stuff. P.S color match the emblems...thats what I did...looks real good! Color matched the cowling aswell. |
I blacked out the badges, I think they look pretty good.
Nice job!
So the appliques slide up or down to catch/release the tabs on backside of applique? Can you post pic of backside of applique...and maybe the door with piece removed? I have a new one on the way for the cracked one. I want to take the other one off without breaking... I will leave facing the sun on hot day before attempting. I would really appreciate this....thanks! BTW I got one for $37. |
Is this what you need?
Perfect
Helps big time.
Had I had this before attempting I probaly would have not broken one of them. Whats done is done though. I will let sit facing sun hot afternoon before attempting the other side. Thanks again! |
If you have a wide nylon trim tool it's the best way to spread pressure without cracking it as well.
I will get..Thanks
| Going to look at a 2007 Yaris 2DR manual Trans hatchback | Cigar_Maverick | New YARIS Purchase Forum | 18 | 04-30-2016 05:29 AM |
| Removing Door Panel for a 2007 Toyota Yaris? | helloopio | DIY / Maintenance / Service | 2 | 04-11-2014 07:22 PM |
| 2006 3 door hatchback seat covers, suggestions, online or in Sydney | aa11 | Cosmetic Modifications (Exterior/Interior) | 5 | 12-27-2013 06:02 PM |
| Need to know if shocks are same Sedan and Hatchback 2007 | Ben_davis | DIY / Maintenance / Service | 2 | 11-29-2013 08:23 PM |
| 2007 Red Yaris Hatchback for sale | llee430 | Willing to Buy by private party | 0 | 01-13-2013 04:50 PM |
