Old 06-03-2006, 04:39 PM   #1
drell42
Drives: Blank
What size resistor?
Okay I have a 2.5v LED that I need to hook up, but i need to know what size resistor to use, ive google ive asked im confused.... PLEASE HELP!
Thanks, Rick!
drell42 is offline   Reply With Quote
Old 06-03-2006, 05:52 PM   #2
Leenis24
lil' town up north
Leenis24's Avatar
Drives: 07 Yaris LB 5 speed Meteorite
use this to find out
http://ourworld.compuserve.com/homep...Bowden/led.htm
v = volts mA = milliampere(Milliampere, an SI unit of electric current, worth 0.001 Amp) Ohm = electrical resistance or electrical impedance
with 1 led, at 2.5v, a 15 mA current, and a 14.2v source(the alternator will push 14.2 volts), it says a 750 Ohm. I would use a resistor higher than that number. I personaly would just use a 1k (1000 Ohm) resistor that way your safe.
Leenis24 is offline   Reply With Quote
Old 06-04-2006, 02:25 AM   #3
johnnyfive
johnnyfive's Avatar
check this out http://led.linear1.org/led.wiz
very handy little helper when it comes to wiring LED's
it will give values for resistors, and pratical array patterns if you are wiring multiple LED's it will even help you with resitor color codes, and give you a wire diagram for the layout :)
johnnyfive is offline   Reply With Quote
Old 06-04-2006, 08:02 AM   #4
Leenis24
lil' town up north
Leenis24's Avatar
hey johnnyfive, that site is really cool, i bookmarked it.
Old 06-04-2006, 10:30 AM   #5
SophieSleeps
Podiatrist
SophieSleeps's Avatar
Drives: Turbo IS300
Thanks, Rick!
You'll need to know the operating current of the LED before you can determine the resistor needed.
A 1/4 watt resistor is plenty. If you go up in wattage it won't do anything...so if you can only find 1/2 watt it won't make a difference.
If you are putting multiple LED's in...I suggest wiring them up in series (connect the + of one LED to the - on another and create a chain) because it seems easier than running them in parallel.
What is your project? Pics? LED's rock
SophieSleeps is offline   Reply With Quote
Old 06-04-2006, 04:53 PM   #6
drell42
Drives: Blank
Thats what i thought so I tried it again i guess that the first one that I had was defective. the LED is so that I know that the neon is on because I dont want to use the fugly switch that came with them!
Old 06-07-2006, 01:33 AM   #7
pennystocks
pennystocks's Avatar
Drives: 07 Civic Si Coupe(Black Pearl)
So you use hot glue to hold em in place? I was thinkin of tryin somehting like this. Bought some LED bulbs, they suck, not bright at all.
also, how many do you think it would take to look nice and bright? and take it the wider the angel the better?
I was lookin at some of the 5 mm leds @ http://www.superbrightleds.com/leds.htm
pennystocks is offline   Reply With Quote
Old 06-07-2006, 01:42 AM   #8
SophieSleeps
Podiatrist
Drives: Turbo IS300
I don't use hot glue to hold them in place. Hot glue prevents the leads from moving and shorting out.
I use superbrightleds.com LED's in 5mm.
Old 06-07-2006, 03:13 PM   #9
pennystocks
So how do you get em to stay in place?
Old 06-07-2006, 07:14 PM   #10
SophieSleeps
Podiatrist
Drives: Turbo IS300
Depending on the surface, you can buy LED surface mount holders.
Do a radio shack search or something.
Speaker Size?? plushDJ In Car Entertainment + Electronics (audio / video / alarm) 20 05-29-2006 01:03 PM
Lets talk wheels birdy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 80 04-29-2006 01:13 AM
