Old 12-07-2021, 04:43 AM   #1
Vins213
Drives: Toyota Yaris Hybrid
Light sensor but no auto lights
Hello there! Cit.
I have the Toyota Yaris Hybrid Active 2018 with light sensor under the windscreen, but I don't have the 'Auto' mode in lights lever (I have the Auto High Beam). If I buy the light switch lever with 'Auto', will it works? I also bought the Cruise Control lever and installed it, the car doesn't have that OEM, but with 20€ now it works without problems!
Vins213 is offline   Reply With Quote
Old 12-07-2021, 07:05 AM   #2
stidnam
Drives: Starlet
It's going to depend on whether your body control module supports automatic headlights. The sensor goes to the body control module as does the auto switch wiring on the headlight stalk. If your car has all that wiring and the body control module supports auto headlights, then I reckon you'd be in luck.
stidnam is offline   Reply With Quote
Old 12-07-2021, 07:19 AM   #3
Vins213
How do I know? Is there any way to see the wiring? Thanks!
Old 12-07-2021, 08:35 AM   #4
stidnam
Drives: Starlet
Option 1: Hook the switch up and see if it works. Option 2: Compare the part numbers of body control modules to see if they differ and get the wiring diagrams to start tracing and testing the circuits
Old 12-07-2021, 10:12 AM   #5
Vins213
option 1 is not possible because I don't have the switch now
for option 2 how do i check part numbers and control modules?
Old 12-08-2021, 08:38 AM   #6
stidnam
Drives: Starlet
Do you have a VIN number for a car with the auto headlights? - toyodiy.com
Old 12-08-2021, 07:05 PM   #7
Vins213
Nope :(
Old 12-09-2021, 07:41 AM   #8
Vins213
What's the part number of the light sensor/wiring diagrams? That's my Toyota:
https://www.toyodiy.com/parts/g_E_20...-CHXNBW_4.html
Old 12-09-2021, 10:09 AM   #9
Vins213
Yes, now I have a Yaris with the auto headlights! And....now?
Old 12-09-2021, 11:01 AM   #10
Vins213
I checked this parts in WIRED panel.
My Toyota Yaris Active with light sensor but not the auto switcher:
82141 WIRE, INSTRUMENT PANEL
82145-0U670
PRE-COLLISION SYSTEM-WITHOUT&WIRELESS DOOR LOCK-WITH(SMART KEY & PUSH START)&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME)&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE
82145-0U680
PRE-COLLISION SYSTEM-WITHOUT&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME)&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE
82145-0UA30
82145-0UA40
82146-0UP10
PRE-COLLISION SYSTEM-WITHOUT&WIRELESS DOOR LOCK-WITH(SMART KEY & PUSH START)&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE
82146-0UP20
PRE-COLLISION SYSTEM-WITHOUT&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE
82146-0UP40
82146-0UP50
82146-0UP60
82146-0UP70
82146-0UP80
WIRELESS DOOR LOCK-WITH(SMART KEY & PUSH START)&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME)&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE&AUDIO-*DA & *BT & 8SPEAKER
82146-0UQ50
82146-0UQ60
82142A WIRE, INSTRUMENT PANEL, NO.2
82140-0D050
And here the Yaris Style with light sensor and auto switcher:
82145-0U670
82145-0UA30
82146-0UP10
82146-0UP60
82146-0UP70
82146-0UP80
82146-0UQ60
82140-0D050
I have all the codes that are on the Yaris Style, right? So...the idea can works!
PS: I don't have the mirror-automatic retractable, so I have the cable drive but not the motordrive or the button inside the car...
Old 12-09-2021, 11:27 AM   #11
Vins213
And also my Yaris Active has:
84140 SWITCH ASSY, HEADLAMP DIMMER
84140-0D270
84140-0D300
FRONT FOG LAMP-WITH & W(RADIATOR LOWER GRILLE=PAINTED)
84140-0D310
FRONT FOG LAMP-WITH & W(RADIATOR LOWER GRILLE=PAINTED)&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME)
84140-0D320
The other Yaris Style has:
84140-0D300
84140-0D310
Well.....that's good
Old 12-16-2021, 10:34 AM   #12
Vins213
It works perfectly!
Old 07-26-2022, 12:32 PM   #13
Vins213
I received two pm but I don't know if the system sent them correctly....so:
the item to buy is this 84140-0D310
like here: https://www.autodemolizionegualtieri...view&id=179012
with the 'AUTO' signature on the light switcher
Second: follow the steps in this video
https://www.youtube.com/watch?v=MugS...ALP2Xw&index=5
if doesn't work, the car doesn't have the correct wiring, my Yaris is an 'Active' one, but now is like a 'Trend' one with cruise control, auto lights and auto folding mirrors installed :D
Old 01-20-2023, 05:01 PM   #14
Electronicgeo
Drives: Yaris Hybrid 2018
Originally Posted by Vins213 View Post
Hello there! Cit.
Hello,can you please tell me what part number you bought for the cruise control ? thanks
Electronicgeo is offline   Reply With Quote
Old 05-10-2023, 05:03 PM   #15
spanishyarisdriver
Drives: 2018 Yaris Hybrid Feel
Hey vins. I have a 2018 hybrid feel in Spain that has auto high beams but not auto lights. You think I could do the same? Also, what did you use to get the auto folding mirrors. I’d be interested in that too. Thanks.
spanishyarisdriver is offline   Reply With Quote
DIY - Exterior lights on when doors are remotely unlocked CTScott DIY / Maintenance / Service 21 07-31-2025 07:30 PM
Tail lights - switch brake light with parking light davidlipski Cosmetic Modifications (Exterior/Interior) 0 06-05-2016 10:34 AM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 11:14 PM
Add auto on/off lights + fog lights using OEM switch inquiry? ricepower DIY / Maintenance / Service 4 04-05-2011 05:46 PM
