![]() Drives: Toyota Yaris 2007 1.5L V4 Join Date: Jul 2018
Engine tune-up
Hello guys,
My mechanic just returned the car to me, as he was fixing the Manual Transmission, and he told me that my car could use an engine tune up (things like cleaning the fuel injectors, checking the spark plugs, cleaning the throttle valve, things like that). My question is, how necessary is to do this, if I do not see any problems with the car? I don't have excessive fuel consumption, vibrations, engine stalling, etc. And if a tune-up is needed, can you tell me which parts have to be cleaned? To see if I can do it at home. |
Apologies, my car is a Yaris 2007 Sedan 1.5L
![]() Drives: yaris Join Date: Nov 2018
You can benefit from a new PCV valve, MAF/Throttle body cleaning and spark plugs, it can all be done for cheap at home with basic tools.
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Routine preventative maintenance is the number one best way to make a car last and be reliable.
I'd do it anyways, spend a few bucks now and save thousands on potential, costly repairs and downtime.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's
Thanks, I have tools to do that so probably I'll do it on my own. Any other things in the engine that I should check?
Gen 3 > Gen 2
Check and/or replace your serpentine belt. I replace mine regardless of condition every 80-100,000kms.
Will take that in mind too, thanks!
yeah the belt really only require 2 sizes and a lil hand work LOL...in all honesty these cars are very simple..and more compareable to a 70s corolla in simplicity for maintinance
change the plugs use good ones, change the air filter, too, cleaning the throttle body can be anoying but even it is simple enough i always laugh when someone says "check the plugs"....imo like a belt..if you dont know when it was last changed then put new on so you know how old it is as far as the injectors go..run a tank or 2 of royal purple "max clean" thru it...im not one for this kind of stuff but a friend made me try it...and this one im sold on, my test subject was my dirt bike to which id clean the carb every year....i havnt touched it in several..in fact i havnt had to touch ANY of my bikes carbs in may many years since useing this stuff once a year....ive also seen it work wonders on high milage injectors |
| Check engine light + vibration | Lisbeth | DIY / Maintenance / Service | 12 | 04-05-2020 10:28 PM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 04:07 PM |
| Really Bad Engine Sludge... | monchito18 | DIY / Maintenance / Service | 27 | 05-14-2014 12:47 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 08:11 PM |
