![]() Drives: 2007 Yaris Hatch Join Date: Aug 2021
Installed a new water pump and alternator and a chirp began to emerge. I at first thought its the alternator seeing as it is a re manufactured brand. Took it off and went back to the parts store to have it bench tested and it passed.
Its not the AC pulley as I ran a belt bypassing it. The new water pump doesnt line up with the other pulleys as the old one did... It sticks out a bit farther than the factory pump. The belt does not sit on it it perfecly in the middle- a portion of it hangs off the right side of the pulley. So I am getting a chirp- not a squeal- due to this. Has anyone else experienced this? |
No. Did the pump have a thick gasket?
Yeah... I almost thought that it wouldn't seal. My brother pointed out to me that the pulley itself of the water pump has lost its enamel and that is likely what is making the chirp. The pulleys are black from the factory but the portion which the belt runs on has turned to a smooth silver and that is what is probably making it.
if the belt is hanging off missaligned then youve got an issue..the "silver" is normal wear and has no effect on the belt noise
take that pump off and get another one..likely the pully wasnt fully pressed on |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
unfortunately, aftermaket parts for toyotas are never worth it, you really have to get factory parts when it comes to service parts or youll have a headache otherwise
#6 | |
i actualy have the same issues with ALL of my vintage stuff from the alfas to the mopars....quality control on replacement parts is NOT what it used to be |
The pump to get is the Aisin water pump, they are an oem supplier.
| Fuel pump upgrade... | Neinris | Performance Modifications | 31 | 12-16-2024 03:27 PM |
| Odd Fuel pump issue. Feeling at a loss. | Marchalis | DIY / Maintenance / Service | 4 | 03-06-2018 08:55 PM |
| Squeal from Engine after replacing Water Pump and Serpentine Belt | vidfan | DIY / Maintenance / Service | 7 | 06-24-2014 10:41 AM |
| drive belt replacement and/or water pump replacement | sociolog | DIY / Maintenance / Service | 9 | 02-10-2014 12:33 PM |
| Water pump belt and pulley - replaced at 36,000mi | cleong | DIY / Maintenance / Service | 3 | 03-06-2009 12:12 AM |
