Old 06-28-2022, 10:33 PM   #1
57pack
Drives: 2008 Yaris sedan
2008 sedan wheel change question
I own a 2008 Yaris sedan since new. The original steel wheels had become very rusty. I purchased a set of used original Toyota Yaris factory alloy wheels with tires and TPMS installed. Now the low tire pressure light in dash cluster flashes on start up then goes steady. The alloy wheels and tires were removed from a 2011 Yaris, checking part numbers the TPMS sensors take the same sensor. I had read that these sensors go to sleep during long periods of nonuse. To wake them up you have to lower tire pressure to 10PSI then reinflate to 35PSI. Has anyone know if this is true? thank you!
57pack is offline   Reply With Quote
Old 07-13-2022, 10:43 PM   #2
57pack
Update…I did the deflate-inflate thing, no immediate result. Then on a 30 mile drive the low pressure light went out! Upon driving home it came back on. A few days later I drove to town about seven miles, and the light didn’t come on and hasn’t since. I’m guessing the sensors have finally awakened?
Old 07-15-2022, 04:43 PM   #3
sh0rtlife
more like they have "charged" from being spun..they keep charge from centrifugal force....or atleast thats what i was told years back
Old 08-15-2022, 03:57 AM   #4
IndestructibleYaris
This is hilarious, what kind of mechanism can make energy from being slung around the inside of a rim?
IndestructibleYaris is offline   Reply With Quote
2008 Yaris Sedan Fuel Door Cable Broke gmermuys DIY / Maintenance / Service 2 02-24-2015 11:17 AM
A question about oil change? mf4361 DIY / Maintenance / Service 4 08-24-2013 12:00 AM
Question on Wheel and Tire soup1207 DIY / Maintenance / Service 1 05-24-2013 11:11 AM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 05:48 PM
