fog light hook up engine side?, otheriwse finished
after scouring the threads looking for a shot of where the fogs hookup on the engine side it seems as if its all dead pics n dead links
ive ordered and recieved a fog stalk, ive had fog lights on the cheep console switch since dec, with my own harness and a wire thru the firewall IE the no dash indication method now that ive got the stalk its time to do it OE IE with dash indication(canadian car with factory tach i see the spot that should light)...stalks in, relay is in...but im at a loss of the exact connection point on the engine side fuse box, i assume its one of the most forward white connections as both of those go down into the front bumper area......but ive got no clue which one and where on them i really need to verify this stalk is still good before my ebay return window closes |
oh come on..your telling me no ones still around who added fog lights?
There's only a handful still around who've really done ANYTHING!
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Come to Canada, there is at least one 2nd gen in pretty much every U-pull I've been in. 3rd gens aren't really old enough to start showing up in U-pulls yet unless its been in a wreck.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's
did a bunch of testing yesterday
2 things #1 with the stalk, you have to add a ground wire to the far right "tiny" hole on the column plug #2 the engine side fuse box "feed" wire holes are the left front side plug top right side holes...the one with just a bunch of green wires in it done..everything works as intended ....now i need to track down power windows |
![]() ![]() Drives: 2009 Yaris 2dr Liftback Join Date: May 2019
Attached is a PDF that I saved when I was installing my fog lights.
I ended up splicing two OEM terminals (PN: 82998-12340) to my fog light wiring kit for compatibility with the engine side wire harness. I got them from here: https://www.ebay.com/itm/193350436215 |
#8 | |
I didn't create the PDF, and it's been over two years since I did my fog light install. I ended up finding the PDF via the wayback machine (https://archive.org/web/).
BTW, if you are stuck on a problem like this. Use the wayback machine to see if the webpages with potential information have archived copies. I have found a lot of useful "lost" information (i.e. pictures, pdfs, attachments, etc.) that way. This site and microimageonline.com are good places for finding old info. |
#10 | |
so thanks for clearing it up with a link!!!!!...i will use it on alot of stuff |
bonus note
i managed to get an un-modified console switch to trigger the dash indicator by plugging the power side of the switch into the left bottom side of the relay plug and stuffing the relay in over top of it i was doing a bunch of troubleshooting trying to figure it all out as i thought i had a bad stalk(missing that ground wire)...it was my understanding that this was bassicly impossible without a modded switch and wiring it thru a complicated setup |
Happy to somewhat help. Good luck with the modification. I'm very glad that I installed the fog lights with an OEM look!
ditto, i just managed to get the bonus of having the stalk AND the console switch to both work, kinda nice having the console "populated" with OE switches...even if the fog switch is a dealer addon switch
![]() ![]() Drives: 07 AT & 08 MT Yaris HB 3dr Join Date: Nov 2021
I'm about to dive into this, I may have to hit you up if I run into any issues.
#16 | |
#17 | |
ok so it looks like the fog stalk is a 3 wire unit an the 3rd wire needs to be grounded i honestly ran it to the first bolt i could find with the column covers off...cant say i remember where exactly but i didnt run it very far
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| 2004 Canadian Echo Hatchback Fog light Kit ( OEM Style ) | mpcv2000 | Cosmetic Modifications (Exterior/Interior) | 26 | 04-06-2017 01:25 PM |
| Driver side reverse light power issue | xdr3amx007 | DIY / Maintenance / Service | 1 | 03-22-2016 03:44 PM |
| OEM Fog Light Brackets? | xavior686 | Cosmetic Modifications (Exterior/Interior) | 15 | 02-16-2014 01:04 PM |
| 2012 Yaris LE Check Engine Light On/Eco Light Off | 2012YarisLE | DIY / Maintenance / Service | 1 | 01-22-2014 12:29 PM |
