![]() ![]() ![]() ![]() Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
brake light
Hi Yarisworlders. My brake light is coming on then going off. It'll come on for a little while, then go off for a little while. Has anyone else had this happen, and if so do you know what it could be? I have a 2009 manual. Thanks.
External brake light, or instrument cluster light?
If it’s the instrument cluster light you got a problem. How’s the level of brake fluid in the master cylinder? It gets very low as your front brake pads where you might need new front brake pads. Do you have a scan tool and are there any codes?
I forgot to mention I did have the brake fluid changed, as it never has been changed before to my knowledge. I hate to admit it, but I'm not sure what the difference is between the external brake light and instrument cluster light. The light that is on/off activated spells out "brake" and it's below the speedometer, if my memory serves me correctly. Thanks, guys.
Also, bronsin, it seems the brake fluid level appears to be stable.
I think I understand the difference between external and instrument cluster. It's not the external brake lights in the back of the car, but the "brakes" light in the instrument cluster. |
bronsin, no. I unfortunately don't have a scan tool. I've made an appt. at the dealership this week. I hope it's not too much money.
Good luck and tell us what happens!
Thank you, bronsin. Will do, for sure.
Took it to the dealer and it turned out they didn't tighten something when they swapped the brake fluid, which led to a leak. They fixed it up for me and stopped the leakage. Glad it wasn't something expensive....
#10 | |
![]() Well at least it’s fixed...and no accident resulted from the dealer induced leak...
True that, bronsin. Grateful for that, for sure.
| HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! | mizhgolightly | DIY / Maintenance / Service | 45 | 05-03-2022 03:59 PM |
| 2007 yaris hatch back 3rd brake light (stop light) | MegaMatt | DIY / Maintenance / Service | 12 | 06-15-2015 11:55 AM |
| Speedometer, brake light, odometer all gone weird | boneyking | DIY / Maintenance / Service | 0 | 07-01-2014 02:30 AM |
| Emergency brake light is on constantly | AdeJong 03 | DIY / Maintenance / Service | 9 | 10-10-2009 10:32 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 05:43 PM |
