#19 |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
you should cut the bump stops, the instruction manual on the tein springs say to cut bump stops 1/2 an inch
#20 | |
#21 | |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
I ordered a pair of adjustable sway bar links, 300-360mm, but they're meant for Hondas. https://www.ebay.com/itm/18476889220...0d22%7Ciid%3A1 They have 10mm end bolts, but I talked to the seller, and they're supposedly including the adaptors for 12mm. Like what's on these other pair. https://www.ebay.com/itm/13337489990...0d22%7Ciid%3A1 Hopefully they work. I have a clunking noise, even before I replaced the struts, I'm hoping it's just from bad sway bar links, but I'm afraid it might be from a worn sway bar bushing.
#22 |
hows the control arms? check the back bolt, its common they break off inside the subframe
#23 | |
Back to trimming the bump stop, my ride doesn’t feel like I’m not even bottoming out. And I’ve tested before and after I went with the Bilstein B8, and the ride is a lot comfortable now. With the stock strut I was bottoming out, and the bump stop was stock length also. So I don’t know if I should trim or not. |
| Tags |
| daily driver, lowering springs, tein |
| Daily driver coilovers...asking for suggestions | Yarflana | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 02-04-2013 10:38 PM |
| 1990 Honda Accord Daily Driver | wowitswil | Cars for Sale by private party | 2 | 04-01-2011 12:46 PM |
| Konig Feathers for Daily Driver??? | MUSKOKA800 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 07-04-2010 07:05 PM |
| Lowering springs, turbo manifold, front driver headlight | Moses | Willing to Buy by private party | 4 | 01-24-2010 03:00 AM |
