![]() Drives: Yaris 2014 2-Door LE Join Date: Oct 2022
your diagnosis of this electrical issue?
2014 Yaris LE 2-door hatchback here.
The 2 items marked in the pic below have lost power. ![]()
Curiously, the "air re-circulation" button (the one with the looping back arrow on it), when pressed, lights up. What would be your diagnosis of the problem? And what will it require to fix, please? (I'm hoping it's something as simple as a fuse replacement.) Thanks in advance. |
not lighting up is likely just a bad bulb and not related to the cig lighter..the cig should be on a fuse mostly by itself
im 99% positive that all of the lighting is a "shared" setup IE all 3 hvac controls get their feed from a single source and ground thru the same wire, so if you had an electrical issue ALL of them would be out not just 1...so you need to replace the bulbs |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
2 different issues, unrelated.
First your cigarette lighter fuse is blown. It is located in the fuse box under the driver's side dash. The cover should have a list of which fuse controls what. Second, the lights for your A/C control have burned out. They are somewhat of a pain to replace....there's a thread around here somewhere explaining how to do it. |
| Tags |
| electrical, fuse |
| Dumbfounding (electrical?) Issue with Yaris door locks | lightdisc2 | DIY / Maintenance / Service | 9 | 11-10-2022 02:28 AM |
| Headlight electrical Issue | SirTopper | DIY / Maintenance / Service | 0 | 01-22-2020 11:36 AM |
| Yaris 2000 Electrical Issue | Rich777 | General Yaris / Vitz Discussion | 4 | 07-21-2017 07:15 PM |
| P/S, Airbag lights on, Radio,fan,brakes light stopped working. | sarabjeet19 | DIY / Maintenance / Service | 4 | 02-01-2016 12:00 AM |
| 2001 yaris electrical issue. | dinger | DIY / Maintenance / Service | 1 | 11-06-2010 05:42 PM |
