Old 11-10-2022, 02:34 PM   #1
maia2012
Drives: 2012 Toyota Yaris Basic
Air Filter Newbie Question
I have a 2012 Toyota Yaris. I heard it was pretty easy to change an air filter - so I thought I'd give it a shot. Everything seemed easy except I notice where I slide the box into the tabs, it doesn't go all the way to the back edge. You can see a thin piece of white which is the exposed air filter. Is this normal? It doesn't seem to be able to go any further. I forgot to take a picture of the old box so I don't know. My OCD is acting up on this - lol. https://ibb.co/pKWkL9S
maia2012 is offline   Reply With Quote
Old 11-10-2022, 03:42 PM   #2
bronsin
bronsin's Avatar
I believe you are good! But if you could post some more pictures I could say for sure!
Old 11-10-2022, 04:58 PM   #3
That is perfectly positioned. You would not be able to close the top if it wasn't seated properly. Here's mine, harder to see the white since there is grime on it.
Old 11-10-2022, 06:56 PM   #4
maia2012
ok, great! Thank you! A relief!
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
Correct air filter not fitting right in sedan? JerseyJeff84 DIY / Maintenance / Service 13 09-28-2011 02:27 PM
Cone Air Filter Size Split Performance Modifications 2 04-24-2009 04:13 PM
damaging or no--cabin air filter roxy84 DIY / Maintenance / Service 3 06-29-2007 01:17 PM
