#37 |
![]() ![]() Drives: Sedan Yaris 2010 Join Date: Dec 2017
10w40 still loosing a quartz every 600 miles
So I got semi-synthetic mannoil 10w40 yet I am still loosing oil on my 2010 Sedan. Is there any other thing I should be looking at or should I just move on to 20w50?
#38 | |
Your engine could be damaged. Piston ring letting too much oil sip through. Sent from my CLT-L04 using Tapatalk |
#39 |
Previous owner was using 20w50 don't know for how long, so I guess I would then continue with that and plan for a change of engine in future
#40 |
I just bought a new 2020 corolla. It comes with synthetic oil, but to keep the warranty you have to change it every 5000 miles normal or synthetic oil.
My wife’s Camry is 15 years old and has 175,000 miles on it all on regular motor oil. It’s time for a new one to what advantage would using synthetic oil be?
#41 |
Knower of little
Drives: None Join Date: Jul 2019
There is a lot of material out there about the pros/cons of synthetics and the basic pros are; better/more additives, last much longer, holds up to stress better but costs much more than conventional. Run what you like for the reasons you like but know that changing brand, composition (additives), quality doesn't make much difference for most production vehicles. Viscosity is incredibly important though so stick to OEM Spec (unless modified, extreme climate or abnormal circumstance.)
Also I'd recommend watching Project Farms (on youtube) oil championship videos, there is a ton of good info in them. |
#42 |
Consumer Reports talks of synthetic oil , https://www.consumerreports.org/car-...l-in-your-car/ . You can get mail in rebates at PENNZOIL , MOBIL1 and other oil company websites . Some take less than a month to receive by mail . PENNZOIL Platinum and FRAM Ultra Synthetic oil filter for both cars .
#43 |
![]() Drives: 2012 yaris le 4dr hatch Join Date: Nov 2022
Airplanes do not change oil, only change filters when light comes on. Then fill to full. Knowing this I change my oil every 5000 miles, but i also change my filters every 1,000 to 2500 miles. Keeps the filter fresh and never allows it to go into bypass mode. lowers the contaminents and it doesnt add much to maintenace costs when I buy filters 12 at a time and use an extra 6 /year.
#44 |
toyota manual says it may burn up to a qt per 1000 miles. never had that happen. was amazed they accept that as normal. never burned a drop until at least 150,000 on any model i had.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| Synthetic VS. Regular oil reliability | captainm27 | DIY / Maintenance / Service | 98 | 01-20-2010 01:46 PM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 04:27 PM |
