Old 02-24-2023, 05:35 PM   #37
sh0rtlife
no i bolted it down fit was fine hole alignment and dowel both....id venture to say that the "carrier" for the hub and even maybe the bearings are actualy the same parts, where the hub pressed into the unit is the only "new part",,,and when you consider tooling costs..the more a manufacturer can re-use the same parts and only change 1 item in the chain the more money they save
for my swap..im keeping the yaris 4x100.....as for the xb1 time will tell is it stays 4x100 or goes 5x114.....i know 114 opens up the world to infinite wheel options and going big brakes is easier tha route
Old 02-25-2023, 10:40 PM   #38
Neinris
Did you get to measure the dimensions of the xB2's rear axle frame? Will it fit in the Yaris? I just want to confirm.
Old 02-27-2023, 01:13 PM   #39
sh0rtlife
sheet ice and snow...give it another couple days or so to melt off and ill get it
Old 02-27-2023, 02:55 PM   #40
Neinris
Thanks!
I completed my rear disc conversion, and I’m pretty happy with the results. There’s one thing I want to redo, move the brackets that got relocated on the middle bar of the H.
I took this pic to see how close 15” wheels gets to the caliper. Although it looks really close in the pic, I think 14” wheels will still work, but not guaranteed until I find one to test fit. Or maybe a little grinding on the caliper would help make some room. Ignore that fact that my wheels are dirty…
File Type: jpeg 596E2A87-CF9F-4DF0-9649-97068BC0F0A5.jpeg (302.6 KB, 60 views)
Old 02-27-2023, 04:51 PM   #41
Compeer
Drives: NCP90 TRD Yaris Manual
Thanks!
Don't grind the caliper, you can induce hair line cracking, mine sit that close as well and its fine.
Compeer is offline   Reply With Quote
Old 02-27-2023, 04:59 PM   #42
Neinris
Not me, sh0rtlife wants to do a rear disc conversion as well, but wants to retain his 14 inch wheels. I said I think might still work with14's, but may or may not require grinding the calipers just a tad. He's retaining the smaller rotor size up front.
Would you try and acquire a 14" wheel and see if it'd fit in the rear?
Old 02-28-2023, 08:48 AM   #43
Compeer
No way its fitting on mine, I have about 2mm spare between the rim and caliper, I will take some pics to show it.
Old 02-28-2023, 04:12 PM   #44
Neinris
Try taking a picture from the inside.
Old 08-02-2025, 02:53 PM   #45
Neinris
Dormant, but not dead…
Thanks to Enviri, I think I finally found the front hub that I’ve been looking for!
Old 08-06-2025, 01:13 PM   #46
remcafee
excellent, now the real question i have for you is it worth all this trouble to have 5 lugs? lol
Old 08-07-2025, 04:41 PM   #47
Neinris
Yeah, I’m not sure either. 😅
I might wait again, I just got these free wheels from my best friend, and I kind of got invested in them. I’m about to get new tires, 195/55 R15. Wheels are DRAG DR21 15X7 ET40, effectively ET35 because of the 5mm spacers. They didn’t fit even with the spacers, so I had to grind the high spots down. I installed slightly longer wheel studs because of the spacers. They gave me an idea of how flushed 7” wide ET35 wheels are.
Old 08-12-2025, 08:09 PM   #48
remcafee
i ordered new wheels, work seeker cx 17x8 +22 offset A disk face and since i run -2 camber i calculated it to be flush with fender, when thry get in ill post some pics, if youd want my old rpf1s we can talk, they are 16x7 +35 offset
Old 08-13-2025, 08:25 AM   #49
Neinris
Thank you, I really appreciate the offer. If I would have known that two weeks ago or so, I would have jumped on it without hesitation. I literally just bought brand new tires for these on Monday. Now I'm trying to figure out how to get rid of the old wheels.
To me these wheels look "OK", better than the white Mini Cooper wheels that I had anyway. I like these better, because they stick out farther and has a little bit of a lip, but I'm more into the plain 5 star or 7 star pattern.
If or when I do the 5-lug conversion, I'm still going with the stock R32 GTR wheels (16X8 ET30) or Circuit Performance CP22 wheels (16X7 ET35). If I had the money maybe Advan TC4 (16X8 ET35).
Back to the 5-lug conversion topic, the rotors I'm thinking of using are from the 2nd Gen Scion xB. they're the same diameter and height as the Yaris SE rotors, but 3mm thicker. I might have to get the Scion xB's front calipers too, I just hope the mounting holes line up. Also I have to still measure the bearing perch? for Scion tCs front hub, the Yaris' front bearings are 39mm wide. I hope the tC's front hub measures the same.
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 07:05 PM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 07:13 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-26-2007 12:10 AM
