Old 02-21-2023, 04:00 AM   #1
MyBlueYar
Drives: 2009 Toyota Yaris
New to me '09 Yaris
Hello all you Yaris faithful: I just picked up a great deal on an '09 Yaris 3 dr, and the one single knock on it was that it only came with snow tires. The original tires were worn quite thin. Pre-purchase inspection showed it was mechanically solid. 5 speed manual. I want to upgrade from the steelies to a different wheel.
In perusing the Official Yaris Wheel & Tire Guide, my eyes happened upon the optional tire sizes. Two sizes that did catch my attention were the 175/65-15 and the 195/50-16.
1. My bigger question is what size wheel will match the above tires. I noticed a few owners who posted pics of their setup, and I liked the 15 X 5.5 Mini Cooper wheels, along with the 15 X 6 Honda Civic Si ones.
2. I'm up here in Seattle and found a set of barely used tires for sale: they're an unconventional 185/55-15 for $160. So for those of you that have a better grasp than I do of these things, pray tell, what options do I have for wheels? My budget is $500 all in.
MyBlueYar is offline   Reply With Quote
Old 02-21-2023, 09:59 AM   #2
Neinris
Welcome to the forum.
I suggest you check this stickyed thread out:
https://www.yarisworld.com/forums/showthread.php?t=5021
And if you're still not satisfied use this wheel/tire calculator, but you'd have to take initial measurements to make it accurate, ie. how far your current wheel/tire is from the fender, etc.
https://www.wheel-size.com/calc/
Old 02-21-2023, 12:17 PM   #3
mannycheckers
Drives: 2009 Yaris 2dr Liftback
I run 15 x 7" wheels (Enkei RPF1) with 205/50R15 tires (Vredestein Quatrac 5). This tire/wheel setup is nearly identical to the OEM 14 inch tires, which allows the speedometer to remain true, and it provides more grip. Due to the Yaris's low HP, I recommend getting the lightest wheels you can afford (<15lbs). The heavier the wheel, the slower your car will feel during acceleration. I would also recommend a wheel/tire setup that leaves some extra sidewall on the tire for comfort. The slimmer the tire, the rougher the ride.
The cheapest new wheel that I could find with the above considerations is the Konig Backbone ($118/wheel):https://www.discounttire.com/buy-whe...ckbone/p/51687
I would recommend getting the Vredestein Quatrac 5 tires (all season tires with snow rating):
https://www.tirerack.com/tires/tires...omCompare1=yes
Alternatively, if you want to use a summer tire, then I highly recommend Continental Extreme Contact Sport: https://www.tirerack.com/tires/tires...omCompare1=yes
Also don't forget to install hub centric rings! Good luck!
mannycheckers is offline   Reply With Quote
Old 02-23-2023, 09:01 PM   #4
MyBlueYar
Wheel selection
Manny & Neinris - thank you both for your timely suggestions. After some more thought, I've decided to go with the Mini Cooper R100 5-Star Spoolers.
The numbers match up very well to the Yaris, and if my research is correct, I'll only need some hub centric rings to use them, 56.1 to 54.1 I believe.
The other specs for these wheels per my search are as follows:
- 13.7 lbs per wheel
- 5.5 X 15
- Offset: 48 mm
- Wheel bore: 56.1 mm
For those who have a bit more knowledge than me, am I missing anything?
Old 02-24-2023, 09:49 AM   #5
Neinris
- 5.5 X 15
- Offset: 48 mm
Correct offset for that wheel is 45mm. Looks very nice, wished it was wider and 16".
Old 03-03-2023, 09:46 PM   #6
Neinris
I thought it was the same person...
https://www.yarisworld.com/forums/sh...537#post841537
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
My 2006 Yaris (Carpento) Carpento Photo-Video-Media Gallery 8 10-30-2022 09:10 AM
Bought a new (for me) 2018 Yaros hatchback, I miss my 2013 Yaris SE Brunno One New YARIS Purchase Forum 0 07-07-2020 11:59 PM
New Yaris 5 DR HB arriving April 5, 2010 mkorejwo New YARIS Purchase Forum 6 04-07-2010 12:39 AM
