![]() ![]() Drives: . Join Date: Mar 2019
Lower Control Arm ball joint bolt seized
Trying to replace the lower control arms on a 2011 Yaris.
The bolt that attaches the control arm to the bearing assembly (locked with a cotter pin (which was removed)) spins without loosening. I placed a jack under the ball joint and added pressure but it wasn't enough. Can I use a pair of vice grips through the ball joint boot and clamp down long enough to break the threads loose Note, I am using thread oil to possible loosen up the threads I am replacing the lower control arms because the rubber around the rear bolt is cracking and possibly failing. |
They can be tough, the ball joint stud is usually held tight in the knuckle while you unthread the nut. I'd soak it for a while, if you have a torch then you can heat the nut up.
#3 | |
Now the forward bolt hits the engine block and can't be removed. Oh, Toyota, you so crazy. |
![]() Drives: 2006 Yaris 2dr hb manual Join Date: Oct 2021
just had to cut mine off with a torch. The bolts for the lower control arms are terrible and I ended up putting new arms on with bolts for a mercedes clk230 (perfect fit/length and same thread). Its a very common issue with these bolts being a bad design from toyota so replace them asap especially with higher mileage
| Ball Joint Warning | tmontague | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 03-31-2024 08:39 AM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Warning - Broken control arm bolt! | CB900F2 | DIY / Maintenance / Service | 460 | 08-23-2020 05:54 PM |
| 2007 hatch front passenger ball joint | Phatdonkey78 | DIY / Maintenance / Service | 4 | 02-16-2019 11:56 AM |
| Ball Joint on Bottom Arm | David Godfrey | DIY / Maintenance / Service | 1 | 04-18-2010 06:27 PM |
