![]() Drives: 2004 1.0 yaris Join Date: Feb 2023
Front brake back plate
Hi,
2004 1.0 Front brake back plates rusted away. It looks like the hub has to come off to replace. Am I right ? |
That is correct, and the process will destroy your wheel bearing. Best just to run without a shield and replace it should the day come when your bearing needs to be done.
as ive managed it with other cars..can you cut a section out of it to slip it in without pulling the bearings?...or is there no access to the bolts?....i know i did it on a 96 supra
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
you can ghetto rig something up, i tried doing that and kinda ruined my knuckle in the process, in the end you should do it right the first time and preparefor a new wheel bearing.
| Problem removing front brake rotor | jkuchta | DIY / Maintenance / Service | 24 | 02-27-2016 10:41 PM |
| MI SSK In-Cabin DIY (Golddeenoh) | BEEF | DIY / Maintenance / Service | 5 | 03-26-2013 02:19 PM |
| 2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 05:48 PM |
| new front brake pads | yaris9876 | DIY / Maintenance / Service | 0 | 10-03-2011 10:12 PM |
| WTB: Front License Plate Mount and OEM wheels/tires | Snarf77 | Willing to Buy by private party | 3 | 07-23-2009 01:43 PM |
