![]() Drives: 2010 Yaris 2 door hatchback Join Date: Feb 2019
Need front wheel alignment specs
I made a camber tool that consists of two bolts attached to a metal bar to which is attached a digital level gauge.
These are the angle measurements I got on all four wheels on my 2010 Yaris two door hatchback: front driver side=88.25 degrees, front passenger side=87.39, rear driver side=89.17, rear passenger side=86.82. So, for example, the front driver side camber would be:90 degrees-88.25=1.75 positive camber I believe. The tool displays zero degrees when laid on a flat surface. What are the factory camber specification degree ranges for the front and rear wheels? I adjusted the toe alignment on this car using a string method. I set the front wheels toed out 1/16" on each wheel for a total 1/8" toe out. One sixteenth toe out per wheel is typically recommended for front wheel drive vehicles. What is the factory toe specification range in inches for a 2010 Yaris two door hatchback? I found this table of alignment specs for my Yaris, but I'm not sure how to read it. https://www.autozone.com/repairguide...96b43f81b3d92d Does the table say that the camber spec range for the front wheels is -.34 to -.50 degrees and for the rear wheels is .04 to .20 degrees? The toe spec range for the front wheels is listed as 13.07 +/-.75. Does that toe range mean 13.07 degrees +/- .75 degrees in relation to a straight line parallel to the car and through a perfectly straight front wheel? What is the spec toe range in inches? Thanks for any replies. |
I found all the specs by doing some searching. Thanks for the help.
![]() Drives: 2007 Yaris 1.5L Join Date: Jan 2022
Hi, I’m looking for the same specs, but for a 2007 yaris 3dr HB. Can you please post your findings.
Thanks, R |
| looking for torque specs on front caliper bolts 07 yaris | mikee07 | DIY / Maintenance / Service | 2 | 10-21-2012 03:36 PM |
| Alignment Specs Question | xnamerxx | Tracking, Racing, Auto-X Forum | 20 | 06-26-2012 12:14 PM |
| Front Passangerside wheel bearing | yaris4062007 | DIY / Maintenance / Service | 5 | 03-09-2012 01:34 PM |
| Damaged Front Bumper PLEASE READ!!! Wheel Cover?! | christolphe | Cosmetic Modifications (Exterior/Interior) | 8 | 04-22-2010 11:52 PM |
| understeer | DOMAV | General Yaris / Vitz Discussion | 31 | 09-30-2009 07:01 AM |
