#379 |
My speedo was off right out of the box. After installing 205/50/16's, I was surprised to discover it was bang on!
#380 |
![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2021
Hello, fellow members. I am not a wheels person and was wondering if a 15-inch 2001 Acura1.6el wheel with 4x100 will fit our 2007 Yaris. I heard the center bore for Acura is bigger, so, will that be a problem? I'm thinking it's a cheap upgrade to our Yaris' rusting steelies.
#381 |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
I think you would want to check how well the Acura wheels locate on the Yaris studs.
Yes, the Acura wheels appear to fit a larger hub. However, there are hub rings available to fit the larger bore size to the smaller hub. These are easily found on line.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#382 | |
#383 | |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
It coincides with what this calculator says: http://www.rimsntires.com/specspro.jsp Punch in 175/65 R14 for the first set and 185/60 R15 for the second set. |
#384 | |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Might be a 3rd gen thing, I dunno. I have never owned a 2nd gen
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
#385 |
Did you mean 175/60/R15? Because 175/65/R15 has a much larger circumference that a 205/45/R16. I would agree 205/45/R16 because that's the close to 175/65/R14's circumference, which is what I believe my car is dialed to.
#386 |
![]() ![]() Drives: 07 Yaris Hatch Join Date: Aug 2017
#387 |
![]() Drives: Yaris 2008 Join Date: Jan 2022
I have a 2008 Toyota Yaris hatchback, and am looking to get 15x6.5 +35mm wheels and 185/60/R15 84H tires. The car is lowered on Tein lowering springs. There is still a little bit of wheel gap. I can measure the wheel gap if needed, or you can tell me another way to know how much it is lowered as I bought the car this way.
With this wheel and tire combination with +35mm offset should I expect to have rubbing issues? Thanks for any replies. |
#388 |
![]() ![]() Drives: 2015 Toyota Yaris LE Hatchie Join Date: Oct 2021
Hello
I am looking at all season tires Yokohama YK-GTX Stock aluminum rims 5.5x15. stock tires 175/65R15 tread width 5.4 Diameter is 24.0 inches (I have the GTX and I am very pleased with it) I am thinking what I want is: 195/60r15 wider by 1 inch @6.4, and is .3 inches taller nearly the same O.D. @24.3 inches or 195/65r15 which is 6.1 inches width (.7 inches wider), 1 inch taller than stock @25 inches I would prefer the tallness (ground clearance, I drive on dirt roads) of the tire. I am not sure if the taller tire will wreck the acceleration and or the milage. Anybody have any experience with this? I will lose 34 tire revs per mile with the 195/65r15 or ~3%. Revs per mile 865 for 175/65r15 vs 831 revs per mile with the 195/65r15 Thoughts? Thanks. Last edited by Calrenman; 05-19-2023 at 09:37 AM. |
#389 | |
195 60's will make you VERY happy, that 1 inch makes a MASSIVE differance...the car will feel more connected to the road, the 65 is a tad tall and you will suffer on torque..which these cars allready suffer at.....i know when i was running my taller old snow tires i HATED it...205/60/15....fwiw i also tested 185s for a couple years and it too was a solid improvement but still felt like it was lacking...195/60s seem to be perfection i belive my 195/60s are on a 5.5 as well, tho it might be a 6 but i know its not bigger..id have to pull them to verify and im not going to LOL i have no experiance with the gtx's but i can tell you the verdistain quatrac5 are AMAZING and easily in the top 3 tires ive owned over 30 years in what id call a 3way tie bridgstone potenzas killer in the summer good in the rain worthless in the snow best "muscle car" tire i know of falken azenis uber badass n the summer, suprisingly great in the wet, and even more strange finds stable traction on black ice and ice pack..not so good in the snow tho..my goto for anything "light" that wont see snow verdistain quatrac5 flat out STICKY in the summer, breaking them loose is neerly impossible, in the wet they grab like a rain tire and its still VERY hard to break them loose even under hard g forces, in the snow and ice they are about as good as a blizak snow tire....somehow this tire just WORKS like it was made for the light weight of a yaris these also grab in gravel and dirt like a rally tire!!!!! i dont know how these will "wear" on a "heavy" car but i can tell you on the "lack of weight" that a yaris is..these tires blew my mind..and continue to do so |
#390 | |
Thanks Short,
I am in a warranty so I am in the yokahama world ![]() the verdistain quatrac5 seem interesting. Same price point too. If the 195/65 stresses the engine noticeably that would suck. Thanks for the heads up. The car is ok at acceleration and any less would not be pleasing. I just put on a rear swaybar and it was worth every penny! Squishy tail no more, it firmed it up. Thank you for sharing your experience. Quote:
#391 |
Short
The tread on my Yokohama tires is Identical to the tires you suggested. |
#392 |
I Purchased new set of Yokohama 195/60/15 YK-GTX tires. I have put a hundred or so miles on them. My milage may have dropped a tiny bit but the ride is tamer and the cornering is much stickier than the stock size tires! I am happy thus far. These are all season touring tires with wide sipes. Kinda reminds me of my old GT Goodyears on my 87 Camero!
#394 |
Apparently there are two different types of drive gears for the speedometer. I bought the one with the part number 33403-19455, but I've yet to replace it because it's really hard to remove the sensor, especially with the limited space I'm working with. Eventually, if or when I swap the engine I'll also swap the speedo drive gear.
#395 |
Drives: 2000 Yaris, Fox Mustang, Town Join Date: Apr 2025
First Gen Yaris 1.0 3-door
Hi!
My son is getting his licence soon and i bought his grandmoms Yaris to him. We plan on getting dome coilovers to it and nice rims. I have been thinking about 15-8" wheels with 25 offset. Has anybody put that kind of rims to a first gen Yaris? Do i need to roll fenders or get fender flares? I plan on getting it very low and tires could be 185/45R15. |
#396 |
![]() Drives: 2009 Yaris RS 4dr Join Date: Jun 2025
Looking to upgrade wheels and tires from stock on my 2009 Yaris RS 4 door... I just bought it, and the springs seem to be slightly lower (or that could be the RS suspension, not sure), they're 'red'. The stock wheel (15x5.5 w/185/60R15) seem to leave a consistent gap all around the fender (not slammed looking, but not jacked up either) so I suspect the drop is very minor (possibly TRD springs)....
My question to you all is, I'm currently looking at a set of Konig Dial In wheels (15x7 +35) in white, and hoping to put on 205/50R15 rubber.... Will this fit? If so, should I expect any rub, or is this well within reach of a mildly lowered Yaris.... PLZ HELP!!! |
| Tamago's guide to ultimate yaris handling | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 99 | 01-25-2026 01:51 PM |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 01:51 AM |
