Old 03-28-2023, 11:08 PM   #55
Compeer
Drives: NCP90 TRD Yaris Manual
Originally Posted by ardianpradana View Post
in real world driving, I'm not noticing any differences
but on dyno, my peak torque shifts 300rpm higher
with stock manifold, the torque drop 25% between peak torque and torque at rev limiter
with RS manifold, the torque drop 19% between peak torque and torque and limiter
Fair enough Im liking how mine runs now with the longer manifold, but may still change it up at some point.
Need to dyno my car to find out and won't do that till i have a tune for it.
Going to get a trd cap and leave it upside down just for remcafe! lmfao
Compeer is offline   Reply With Quote
Old 03-29-2023, 09:29 AM   #56
Neinris
Drives: 08 Yaris 3 Door Hatchback
Originally Posted by Compeer View Post
...Going to get a trd cap and leave it upside down just for remcafe! lmfao
put the extenders on the stock intake...
Neinris is offline   Reply With Quote
Old 05-16-2023, 06:46 PM   #57
ElMagnifico
Drives: 2012 Sedan
Originally Posted by mitch9521 View Post
No. Stock injectors and TB, the throttle response doesn't bother me after I swapped in the Lexus IS250 pedal that gets rid of the dead spot and makes the pedal heavier feeling.
Part number for pedal?
ElMagnifico is offline   Reply With Quote
Old 05-22-2023, 01:15 AM   #58
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
78110-53120
It will either require a Japan market Vitz NCP131 pedal bracket to work OR you can fab up something yourself. Electrically it is plug and play.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 05-26-2023, 06:57 PM   #59
Neinris
78110-53120
Mitch, do you still have the 1ZZ TB installed? If so, did the pedal reduced/eliminated the rev hang?
Old 05-26-2023, 09:59 PM   #60
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Nope, stock TB. I have a port matched 1NZ manifold + 1ZZ TB sitting in my shed, never could get it to play nice with my car so its shelved for the time being. Lots of life events happening, so.
To answer your question; no it didn't change the rev hang. It just made the pedal even with the brake for easy heel toe downshifts and made the pedal heavier which I find much easier to modulate. It also eliminated that annoying dead spot the stock pedals have.
2014 NCP131 5 Speed
Old 05-28-2023, 01:51 PM   #61
sh0rtlife
i wonder how well that pedal plays with the 1.8 tb....i know the TB removed "most" of the dead spot and rev hang...its still there but its been cut by more than 1/2
ive had no luck finding the pedal
Old 05-28-2023, 04:14 PM   #62
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
I came across an IS250 at a U-Pull, literally paid 20 bucks for it. Theres been a few more I've come across that I have passed on.
2014 NCP131 5 Speed
Old 05-28-2023, 11:07 PM   #63
sh0rtlife
ontario vs OR...yeah...hell i havnt seen a 5dr yaris in over a year
Old 06-04-2023, 02:00 AM   #64
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
90% of Yari' here are 5 doors. Seeing a 3 door 3rd gen actually turns my head, they are quite uncommon. 2nd gens are a little more common.
2014 NCP131 5 Speed
Old 06-04-2023, 08:26 PM   #65
sh0rtlife
3dr mk2s are uncommon but seen here, 5drs dont exist, mk3 5drs are even pretty uncommon
sedans fall from the skys....but when it comes to "wrecked" hatches..they dont exist at all
ive got a run into BC schedualed to pickup some stuff from MIL's storage, and im hoping i can hit a yard up there with a 5dr in it for some last tidbits at the same time
still have yet to complete the power window swap due to missing pieces....i can live with the door panels, but ive only managed to get 1 rear regulator and harness..fronts full power atleast
Old 06-04-2023, 10:39 PM   #66
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Yeah definitely hitting up a Canuck U-pull would be a good idea. Fairly easy to find a 5 door with power windows here.
2014 NCP131 5 Speed
Old 06-05-2023, 02:47 AM   #67
sh0rtlife
i was going to hop the ferry out of port angels to victoria, but i may go the long way round thru vancouver just so i can have a possibility of 2 yards...
would be extra amusing to get the door panels out of canada..since it IS a canadian 07 5dr living stateside
Old 07-13-2023, 10:59 AM   #68
Compeer
It is! Its crazy torque down low now with the other mods Ive done, very very easy to loose traction now in 2nd and in the wet in most gears lol.
I haven't been active for a while because the car currently is just damn fun to drive, the Throttle body change, intake runner spacer, intake tube and airbox mod are just working so damn well. The car has no dead spot any more and will DURTTTTT all the way from 1.8krpm..give her the beans and it lights up till red line. With only 6400rpm max it feels like I never get off the torque curve. I dont think I will change the manifold to the shorter one as currently she destroys the tires in 1st and 2nd gear and feels like you are actually driving a hot hatch.
Old 07-19-2023, 03:17 AM   #69
sh0rtlife
id kill for the spacer..they dont seem to exist here.....all said mine pulls real good for everything else ive done
Old 08-03-2023, 05:06 AM   #70
Compeer
Its the EGR plate that I used JB weld on to seal the holes on. where ever you find the shorter manifold you find the egr plate, it bolts on to our block normally, just means you have to loose the top engine cover.
Old 08-30-2025, 09:44 PM   #71
Sokal13
Drives: 2013 3 Door
The gen 3 Vitz RS has its own OEM pedal bracket so I just ordered one from RHDJapan. I don't know if it will work in a 2nd gen though.
Part number is 78114-52020.
I tried to PM you but I think because I’m a lurker I can’t actually send PMs.
I’m trying to replicate your set up with the IS250 gas pedal. I got the bracket from Amayama and maybe I’m just being stupid, but I can’t seem to figure out how to mount it.
Did you need to drill and tap a hole or were you able to line the bracket up? I’m assuming the bracket is longways vertical like the parts diagram shows.
The Amayama diagram isn’t very helpful.
I’d appreciate any help you’re able to offer. I’d figure I’ll take photos and write it up for the next person while I’m at it.
This is what the mounting spot looks like on my 2013 USDM Yaris.
Thank you for your time.
Sokal13 is offline   Reply With Quote
1ZZfe mod info darkMINI Performance Modifications 21 07-13-2011 12:41 AM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
