#55 | |
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
Need to dyno my car to find out and won't do that till i have a tune for it. Going to get a trd cap and leave it upside down just for remcafe! lmfao |
#56 |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
#57 |
![]() Drives: 2012 Sedan Join Date: Nov 2018
#58 |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
78110-53120
It will either require a Japan market Vitz NCP131 pedal bracket to work OR you can fab up something yourself. Electrically it is plug and play.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
#59 |
#60 | |
Gen 3 > Gen 2
To answer your question; no it didn't change the rev hang. It just made the pedal even with the brake for easy heel toe downshifts and made the pedal heavier which I find much easier to modulate. It also eliminated that annoying dead spot the stock pedals have.
#61 |
i wonder how well that pedal plays with the 1.8 tb....i know the TB removed "most" of the dead spot and rev hang...its still there but its been cut by more than 1/2
ive had no luck finding the pedal |
#62 |
Gen 3 > Gen 2
I came across an IS250 at a U-Pull, literally paid 20 bucks for it. Theres been a few more I've come across that I have passed on.
#63 |
ontario vs OR...yeah...hell i havnt seen a 5dr yaris in over a year
#64 |
Gen 3 > Gen 2
90% of Yari' here are 5 doors. Seeing a 3 door 3rd gen actually turns my head, they are quite uncommon. 2nd gens are a little more common.
#65 |
3dr mk2s are uncommon but seen here, 5drs dont exist, mk3 5drs are even pretty uncommon
sedans fall from the skys....but when it comes to "wrecked" hatches..they dont exist at all ive got a run into BC schedualed to pickup some stuff from MIL's storage, and im hoping i can hit a yard up there with a 5dr in it for some last tidbits at the same time still have yet to complete the power window swap due to missing pieces....i can live with the door panels, but ive only managed to get 1 rear regulator and harness..fronts full power atleast |
#66 | |
Gen 3 > Gen 2
#67 | |
would be extra amusing to get the door panels out of canada..since it IS a canadian 07 5dr living stateside |
#68 |
It is! Its crazy torque down low now with the other mods Ive done, very very easy to loose traction now in 2nd and in the wet in most gears lol.
I haven't been active for a while because the car currently is just damn fun to drive, the Throttle body change, intake runner spacer, intake tube and airbox mod are just working so damn well. The car has no dead spot any more and will DURTTTTT all the way from 1.8krpm..give her the beans and it lights up till red line. With only 6400rpm max it feels like I never get off the torque curve. I dont think I will change the manifold to the shorter one as currently she destroys the tires in 1st and 2nd gear and feels like you are actually driving a hot hatch. Last edited by Compeer; 07-15-2023 at 04:25 AM. |
#69 | |
#70 |
Its the EGR plate that I used JB weld on to seal the holes on. where ever you find the shorter manifold you find the egr plate, it bolts on to our block normally, just means you have to loose the top engine cover.
#71 | |
![]() Drives: 2013 3 Door Join Date: Jan 2023
I’m trying to replicate your set up with the IS250 gas pedal. I got the bracket from Amayama and maybe I’m just being stupid, but I can’t seem to figure out how to mount it. Did you need to drill and tap a hole or were you able to line the bracket up? I’m assuming the bracket is longways vertical like the parts diagram shows. The Amayama diagram isn’t very helpful. I’d appreciate any help you’re able to offer. I’d figure I’ll take photos and write it up for the next person while I’m at it. This is what the mounting spot looks like on my 2013 USDM Yaris. ![]() Thank you for your time. Last edited by Sokal13; 08-30-2025 at 11:22 PM. Reason: Corrected year |
| 1ZZfe mod info | darkMINI | Performance Modifications | 21 | 07-13-2011 12:41 AM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 08:15 PM |
