Old 10-04-2023, 04:35 AM   #1
ssammut
Drives: Yaris 2007 D4D
yariss 2007 rear wiper arm
Hi,
I have a 2007 yaris d4d. VIN start with VNK. I bought a replacement rear wiper arm 85241-0D020 however it does not fit. The original one I have is splined same as .
However the new one I got with OE 85241-0D020 does not fit at all and has no splines either. Sames as
Is there a different part number to search for?
I got the part number 85241-0D020 using the VIN number on the parts catalogue https://www.amayama.com/.
Hope you can help!
ssammut is offline   Reply With Quote
Old 10-04-2023, 07:36 AM   #2
Why are you replacing the entire wiper rather than just the blade assembly?
Old 10-04-2023, 08:11 AM   #3
ssammut
the first image is from an online source, mine is actually broken.
Old 10-04-2023, 04:32 PM   #4
rpster
Drives: '07 Yaris Liftback
The only other option is 85241-52120, which also code matches for the diesel yaris. You can also double check the match on toyodiy.com.
rpster is offline   Reply With Quote
Old 10-09-2023, 05:09 PM   #5
sh0rtlife
i have a hard time beliving a diesel yaris uses a different unit than a normal yaris.....however non OE parts like this often times have no splines and get "cut" when bolting them down
Rear wiper pressure? Pinchlite General Yaris / Vitz Discussion 2 01-06-2018 05:00 PM
2007 Yaris Hatchback Rear Wiper Arm Compatibility Cigar_Maverick DIY / Maintenance / Service 4 12-10-2017 12:28 PM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
feeler: rear window wiper delay yaris2010RS Performance Modifications 7 03-07-2011 01:25 PM
